Lilft options for 8' garage
Not familiar with the epoxy inserts, but regardless, looks like I am going to have to call a concrete company. I may be able to use the concrete inserts on the other column that just had an anchor fail.
I'd unbolt everything and move the columns out of the way. Pull out or pound through the inserts that are loose, go to home depot and ask for a hilti epoxy anchor of the same size and install them. If the expansion anchors are tight for the rest you can use them if they take torque. here's the HILTI stud anchors that would match your bolts:
http://www.us.hilti.com/holus/page/m...&nodeId=-60125
PS: once the holes are too big the expansion type anchors simply don't have enough bite on the wedge section to work, the have a pretty narrow range of hole size that works. Also any pounding on them for alignment will weaken the hold. For soft or cracked concrete, much better solution to use the adhesive type anchors. We use these all the time for retro fit construction, they are very strong, typically the bond is stronger than the surrounding concrete. Make sure they are in the right place before they cure.
Thanks so much for the input. Not sure how thick the concrete is. I ran out of bit depth at about 6" so pounding through isnt an option. Regardless this looks like a good solution.
I think I'll be able to get this to work. The cracking issue can't be more than about an inch deep. I think I can repair that easily, then use the Hilti system mentioned above.
