"Redneck" Transaxle Mount Repair at Road Atlanta
Old 03-14-2012, 10:30 AM
johntorg
johntorg's Avatar
Default "Redneck" Transaxle Mount Repair at Road Atlanta
I broke my stock transaxle mount in the Saturday Lightning Race at Road Atlanta. with no replacement available, Quentin Boatright, suggested that I try to tie the torque tube in place with ratchet straps and a piece of wood (for vertical alignment). It worked like a charm. Thanks Quentin!
Old 03-14-2012, 10:33 AM
f1rocks
f1rocks's Avatar
Note to self.....
Bring two spare transaxle mounts to RA next weekend. One for me and one for any of the "rednecks....."
Old 03-14-2012, 10:55 AM
johntorg
johntorg's Avatar
We don't need no stinkin' transaxle mounts
Old 03-14-2012, 02:19 PM
67King
67King's Avatar
To quote a well known "redneck" not too far from Road Atlanta, Lewis Grizard, "Damn, brother, I don't believe I'd'a told that!"
Old 03-14-2012, 03:11 PM
Duke of Understeer
Duke of Understeer's Avatar
To quote the great Joe Dirt: "Dang"
Old 03-14-2012, 03:21 PM
winders
winders's Avatar
You raced with that? Wouldn't pass tech anywhere I know....
Scott
Old 03-14-2012, 05:47 PM
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
Scott
Why not?
Old 03-14-2012, 05:55 PM
winders
winders's Avatar
Originally Posted by MUSSBERGER
Why not?
You can't be serious....
Scott
Old 03-14-2012, 07:35 PM
johntorg
johntorg's Avatar
Sometimes you gotta do what you gotta do. It actually shifted a lot better with the torque tube tied down than when the mount was in the process of failing.
Old 03-14-2012, 07:55 PM
winders
winders's Avatar
And if that "fix" failed and cause you to wreck and take out someone else?
Scott
Old 03-14-2012, 10:26 PM
bsztanko
bsztanko's Avatar
Not sure I'd brag about that one.
Old 03-15-2012, 07:38 AM
johntorg
johntorg's Avatar
The original mount was still securing the transaxle just allowing it to move all over the place, making shifting difficult. If both ratchet straps failed (Highly unlikely) I would be back where I started with difficult shifting.
Old 03-15-2012, 08:54 AM
disasterman
disasterman's Avatar
Racers do things like that. Good hillbilly engineering at the track, it appears to be pretty locked in there. The fact that it was Quentin approved helps.
Did he run his green monster?
Old 03-15-2012, 09:05 AM
johntorg
johntorg's Avatar
Yes, he ran and finished 2nd overall and 1st in class both days.
Old 03-15-2012, 09:22 AM
4WHLDRFTN
4WHLDRFTN's Avatar
Redneck Engineering Exam
1. Calculate the smallest limb diameter on a persimmon tree that will support a 10 pound possum.
2. Which of the following cars will rust out the quickest when placed on blocks in your front yard?
a. '66 Ford Fairlane
b. '69 Chevrolet Chevelle
c. '64 Pontiac GTO
3. If your uncle builds a still that operates at a capacity of 20 gallons of shine per hour, how many car radiators are necessary to condense the product?
4. A pulpwood cutter has chain saw that operates at 2700 rpm. The density of the pine trees in a plot to be harvested is 470 per acre. The lot is 2.3 acres in size. The average tree diameter is 14 inches. How many Budweiser Tall-Boys will it take to cut the trees?
5. If every old refrigerator in the state vented a charge of R-12 simultaneously, what would be the decrease in the ozone layer?
6. A front porch is constructed of 2x8 pine on 24-inch centers with a field rock foundation. The span is 8 feet and the porch length is 16 feet. The porch floor is 1 inch rough sawn pine. When the porch collapses, how many hound dogs will be killed?
7. A man owns a house and 3.7 acres of land in a hollow with an average slope of 15%. The man has 5 children. Can each of the children place a mobile home on the man's land?
8. A 2-ton pulpwood truck is overloaded and proceeding down a steep grade on a secondary road at 45 mph. The brakes fail. Given the average traffic loading of secondary roads, how many people will swerve to avoid the truck before it crashes at the bottom of the mountain? For extra credit, how many of the vehicles that swerved will have mufflers and uncracked windshields?
9. A Coal Mine operates a NFPA Class 1, Division 2 Hazardous Area. The mine employs 120 miners per shift. A gas warning is issued at the beginning of 3rd shift. How many cartons of unfiltered Camels will be smoked during the shift?
10. How many generations will it take before cattle develop two legs shorter than the others because of grazing along a mountainside?
Quick Reply: "Redneck" Transaxle Mount Repair at Road Atlanta
