AiM Data Sessions are AMAZING!
#46
Paul
I just upgraded a unit as well. What I found is that it needs to see satellites then it gives you the arrows to scroll thru your pages, strange. The listed upgrades in the release history looks like these are good changes.
#47
Basic Site Sponsor
Basic Site Sponsor
Received 3,062 Likes
Peter
I was trying to set up a video this weekend using Long G as a choice in the brake config in Smarty Manager. It didn't seem to let me set a range so that I could use something like 1 G as the "full brake" measure. I didn't totally sort it out because I was working data on about 6 cars. Any pointers? I'm going to Watkins Glen next week and want to get this working properly. It did work great in the data analysis, just need to sort out the video.
Will keep working on that. For now, I'm just looking at the numerical reading in the longg portion of the friction circle. Making sure it's sudden, strong and even across the entire braking zone. Also, not using the braking bar on the SC background unless I have brake pressure input from a late model car, like not using the throttle position unless I have that input.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#48
also, if you choose 'preformance' mode - in the menu itself you cannot see 'display setup' option at all and cannot configure custom screens. odd.
plus, smartycam screen never came back and i need it as i use it all the time to stop recording when i do not want it, it is a very convinient interface, no idea why they decided to drop it off completely. all in all something seems strange about this last firmware. i will wait for next one, if it will come or will stay with 46.2.10. also, i used point to point markers in the 46.2.10 version and it worked fine and overall i did not have any issues with it yet. seems to work fine.
#49
We've had some discussions about using Longitudinal G as a source of Brake data.
The following shows a lap using RS 2 Analysis. The graph is Speed, Longitudinal G (in the early SOLO units, this was labeled as Latitudinal G), the the "Brake" which was derived using a math channel.
The second picture shows the math channel that needs to be created in your RS2 Analysis.
What this does is to create a brake trace that is not cluttered with the throttle influence on Long G. To build this math channnel in your RS 2, replace the "ACC_Laterale" with the channel in your data that provides Longitudinal G.
I'll work on this further to see if I can get a good Throttle trace from this data.
