PCA Specbox History? WTF...
#61
I guess that is another benefit for the less sticky Toyo for Spec Box.
#62
I believe Eric ran in a class that allowed stickier tires, sticky tires when spun fast in the air and then hit pavement cause a huge load on the R&P. A less sticky tire would just tend to spin more when it hit the pavement causing less load, or shock load if you will, to be transfered to the R&P.
#63
Perfect Angel
These cars are fun. So light and nimble. The power to weight is right at the GTS2 limit. I came out of an E stock 911. My thinking was that I paid my dues in the older platform and it was time to learn in a modern car. This was the perfect choice. The cars are night and day. The Boxster requires much less effort but, as I learned, you can't drive it like a 911. While it is different from that classic 911 experience it is loads of fun primarily due to the weight. ABS and a modern trans make big differences too.
Very fun to race.
Very fun to race.
#64
Former Vendor
This isn't the ideal forum for a rules debate, and with the series/rules up in the air, I'm not sure if there is an ideal forum. However, the "factory option" argument is really weak; as someone mentioned before none of the suspension was optional, and neither is a composite top or 3rd radiator.
I saw a number of SPB track records broken this year, so obviously, the cars are being driven harder than they were last year, and certainly the years prior. Consequently, it makes sense to revisit an old decision with new opinions.
Also, it is tough to draw a LSD comparison between Spec944 and SPB. The 944 is VERY polar, with front engine/rear transmission. I would argue that a 944 does NOT need LSD. A mid-engine Boxster has a VERY different inertia, and a LSD has a much more dramatic effect.
#65
The counter argument is the car will be alot better to drive for all with an LSD.
Not an easy choice....
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
#66
PCA 2012 rules are posted. No big surprises at all.
The RA1 in square/staggered is the new spec tire
we are still on the PSS9s with stock valving
Lexan windshield added
trans cooler option added
removal of smog equipment
#68
I'll race anything, I vote for "Spec Golf Cart"
We all show up at a track like Daytona, or Mid Ohio where they have a golf cart rental company, seal the lids as they come out of the rental company so there is no playing with restrictors, etc, and then we race around the track !
Just think of the benefits, low cost, instead of 3 wide thru turn one we can probably go 6 wide ! Drafting ? They already come with those rubber bumpers, we won't even scratch the paint !
#69
Perfect Angel
#70
Hi Paul,
Is that a front or rear (or both) Lexan windshield?
I am hearing that the new RA-1 tires ( next spring ) are going to be a moulded tire, and will come @ 4/32nds from the factory, did your group here the same?
#71
Hey Chris hope you are well. Been meaning to call and check in
I understood it to be Lexan windshields being allowed. We were always allowed a non-glass rear window with the fiberglass tops.
I had not heard any kind of news regarding the RA-1 at all. It would be nice to not have to shave them before use. I wonder what our options would be for rain tires assuming the 4/32 isn't desired, I would hope we can still get the full tread RA1 for use as rain tires.
#72
Nope. Just really quick shifts with the standard shifter. I'm not claiming I'm not hard on the car, I'll admit to that. I'm just saying that the LSD would reduce the load on the trans, and could increase rear tire life as well.
#73
I think my car could definitely be considered an outlier when you look at the numbers though. My specBox has proved itself to be the quickest car on the west coast coast this year, and I don't think any would argue against that. It certainly gets driven to limit and then some. If anyone is going to find the weak parts, I will, and I did.
It's not the fastest car out here because of horsepower. It's driven hard, shifted quick, has inside wheels spinning, and spends a lot of time curb surfing.
A season for us on the west coast is a bit longer as well. We run from January to December and I have 38+ track days on the car this year. The short track events are actually much harder on the car than the large high speed tracks.
#74
Wow.. a tranny every 8 track days... that's about the frequency I change oil in my 993. My engine and tranny are 15 years old.... Over three hard seasons, I've missed exactly two DE run sessions (shift fork) and only one single race DNF (half shaft) due to mechanical failures in my 993.
I've been observing with a lot of curiosity and interest about this spec boxster idea, but with engines and trannies considered to be consumable items, and guys buying sticker tires for every race weekend, I'm just not convinced yet that this class makes sense.
#75
Perfect Angel
Ninja. I don't know anyone who goes thru engines or transmissions as described above. Those who want to buy new tiires at every event will do that no matter what series they run.
