PCA Rolex Video thread
The Penguin King
This should be good...
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
From what I saw they are both at fault, the yellow car chopped, the white car didn't even try to avoid the collision like it was owed to him since he had a cup car.....
unless you take a bunch of curbing there is no way that pass was a good idea. He would have been better to try and leave room, pass just before T8 and keep you held up behind the yellow car all the way to the bridge.
agreed
T7 is not a good turn to try a late brake pass. There is very little grip as the turn drops just before the apex and the curbing has two levels you can only lean on the first level. I have seen Miatas go straight all the way to the wall after trying to braking too late. There was a car width if the inside curbing was used.
Greg, The radius on that turn is very large and car width yes, but not possible to make the corner and be faster or even with the lead car by not cutting the apex. IMHO the yellow car gave enough position and the attempted pass was optimistic at best. I passed cars in there multiple times, but you take on a load of responsibility doing so. If you don't pass before the next turn you cannot get a clean pass before the bridge straight which feels like eternity.
Before the crash, I was willing to jump the curb to avoid Dan (always leave an out!) but he was aware and stayed wide, thanks!
http://vimeo.com/27260930
