SmartyCam. Anybody?
#46
don`t worry, smartycam is a great system, you`ll like it. what I was talking about was the way to make custom track maps for your locations, like auto-x course you run or any track which is not in the supplied database. there are many ways to skin a cat, what i posted above is just one of them.
#47
Well, I don't really know what I am talking about here (how's that for a convincing start), but I did read in Chris Brown's book (about racing data systems) that you need a much higher sampling rate for the GPS data on the track, which I am inferring to mean that perhaps navigation system sampling may not be as critical.
But like I said, I don't really know the answer.
#48
On the AIM and most GPS based data systems the antennas work better on the roof of the car. The reason being is they get a better GPS feed from the satellites as there is very little to interfere with the feed. If you place it on your dash the antenna may get the read from the satellites straight overhead, directly in front, etc but it is having trouble getting a read from the satellites behind the car as the roof is getting in the way. And this changes as we move around the track in a moving car. This is why on track we get spots where the GPS will drop off or a change in speed suddenly occurs when we look at the data. The antenna on top of the car helps eliminate some of these issues compared to the antenna on the dash.
#49
The Tom Toms and Garmins work at a slow speed compared to what we are doing on a racetrack. They have the maps preloaded and the software will somewhat predict your location based on speed and current heading information from the GPS satellites. The antennas in these units don't need a constant GPS signal for this reason.
I know....
Have been using Data logging devices on my racecars for almost 15 year.... and GPS based units aince the stone ages in data logging.. DL-90, G-cube etc..
The op has a 944 i believe.. you can have the antenna under that "skylight" rear hatch and get locks on to all satellites that are available..
In any event the logarithms that draw the track maps are using some sort of correlation functions that sort the data... basically averaging for best fit curves etc..
I love the vbox...2cm accuracy..
no way no how...
On my 911 I really just tossed the antenna on the dash... the only time I had signal loss is at the Glen....In the laces.... the trees caused the signal loss..
#50
OK, so I raced last weekend and used the SmartyCam. I was at Monticello Motor Club, which is not a listed track. I went to the S/F line and captured the coordinates, and everything seemed to work just great, until I realized that it didn't map out the track on the overlay. What up?
#51
Frank:
You can change was is displayed on the overlay. You do that in Smarty Manager. Since you are not pulling RPM data, you can remove the tach, change the size and location of the speedometer, insert other things like logos, a photo of your car etc. Open Smarty Manager, go to Smarty cam configuration. On the right are a series of tabs. One is labeled map. Click on it, then you will see "track map." Drag and drop what you would like to have displayed over on the left, save the configuration. Take this time to remove the tach. Make sure your camera is connected to your laptop and transmit the configuration to your camera.
#53
#54
In Analysis, export the test to your desktop. Then open Smarty Manger and either create a new track or add to an existing track that only has SF coordinates. you want to load track shape. Navigate to the .gpk file on your desktop and you will now have all the laps from that test. After you load the track shape make sure you uncheck the box that says show all laps. This will allow you to select the lap that you want to be displayed on the video. You don't want your out lap or your in lap. Once you have selected the lap, hit save. Now transmit this track to tue SmartyCam.
#55
I don't get it. And how do I load coordinates from tracks that don't even show up on Google Earth?
It seems that NJMP and Monticello are too new. Or is it just me? Do you guys see these circuits on Google?
#56
You can load them manualy with the camera or if you have a logger with a display you can "set lap beacon" via the display.
On the SmartyCam you go to lap managenemt, stand at SF and press "fix" this will set the SF beacon.
Or you can call me and I can walk you though it as well.
727-647-2674
Jordan
727-647-2674
Jordan
#57
Is there an easy way to generate labels? I have it setup to display coolant and oil temps, but I dont see anything in the menu to label them as such. My brake seems to be swapped w/ throttle, though the throttle isnt reading anything. I'll have to play with that. What do people normally set for the Brake/throttle in the SmartyCam manager?
#58
Basic Site Sponsor
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
http://vimeo.com/26564998
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#59
Basic Site Sponsor
Basic Site Sponsor
I can see his point in evaluating system to system, but for tools to help drivers gauge improvement, they're all more than adequate.
#60
