Gurney Flap Study
so, back on topic, i reviewed some of the graphs. you all know the "T" graphs dont apply to us. (tail sections for airplanes) BUT, if you look at the lift coefficients, and the drag profiles, it sure looks like .25 " GF on our wings would provide almost double the angle of attack (say 6 degrees normally, going to 12 with the GF) So, is that good?? I dont know. you could just move the wing to 12 degrees too and get the same Cl.
Now, the Drag part. it looks like at the same Cl, the drag goes up almost double. So, unless Im reading the results wrong, the Gurnery Flap increases drag, based on the same lift.*
(see diagram 14 for drag, and figure 4 for lift vs AOA)
* lift coefficient of 1.0 has drag of .05 without GF. with GF, same 1.0 Cl, Cd goes to .06. (20% increase in drag)
So, if that is true, what are we really trying to do with the GF?
What is its true goals.
is there a second per lap lurking there? Doubtful
I dont see it. looking at the charts,
I was looking at 2% GF, becauase thats generally what we see on race cars. about .25" But even still, even at the 5% GF, you increase the AOL by 7.5 degrees (from 5 degrees AOA to 12 degrees AOA.)
At the same lift , say Cl of 1.0, the drag for no gurny is .075 Cd, while with the gurney, its 1.0 Cd. looks like the drag goes up by 33% for the same lift, but a higher angle of attack with standard wing, no Gurney Flap.
I think that is the net net of all this. you max out near 12 degrees or so AOA and you need more downforce, add a gurney as it will increase downforce as the same as it would be to increase AOA, but is not limited to the standard wings max lift levels. It increases the max lift levels.
Interesting paper. thanks for posting!
Mark
edit: another way to look at this as well, is if you care about drag due to downforce, the clean wing can be at Cl 1.2, and produce the same drag as the gurney flap lip'ed wing at only Cl 1.0. 20% more lift, same drag as the gurney flap.
again, i think the gurney flap is to increase downforce when you are near the limits of the wing.
Mark
Figure 4 shows that you can get the same increase in lift as a 5% GF by increasing the angle of attack 7.5 degrees. Given that the 5% GF increase drag by 335%, I would like know the increase in drag by increasing the angle of attack of the wing (without) by 7.5 degrees.
Edit: I think I answered my own question. This page http://www.lets-go-fly.com/Lift%20an...the%20Wing.pdf suggests that increasing angle of attack by 7.5% equates to an increase in drag of 500%, which is clearly greater than the GF.
Admin
https://rennlist.com/forums/997-gt2-...ghlight=gurney
I will test a new one on the cup wing and want more data!
Probably both of us are wrong..but still I like the discussion : )
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Gurneys are also quite effective placed on the leading edge of cooling ducting exits as they will help evacuate the duct.
Basic Site Sponsor
Basic Site Sponsor
I put a piece of 3/8" aluminum angle on my RSA to make a Gurney flap, but now my screen door doesn't close properly anymore.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I could do more testing, but I am to lazy to mess with it.
I already know it is more then a second faster, maybe 2 seconds with the splitter. They probably balance out:
The only research I do is steal parts of 2010 CUP cars when no one is looking and put them on mine. They all just bolt on and the CUP cars seem to go around the track pretty good, so if it works for CUP car, it works on mine.
They do enough research I figure. I scored a LSD front splitter gurney flap (shaped slightly different) and little fender flaps so far. Even my BBS are 3 piece CUP like, just different CL.
I even Vinyl wrapped it as do all the CUP cars! Maybe less Cd?
I have no idea how much down force the lip and flap make.
I agree the difference is big.
It's not even 2 minute lap:
Session 2 I did steady 12 laps, all 1:21's 1x 1:221 and 1x 1:208. Session after no changes at all besides adding the lip and flap and maybe 1/4 tank less gas. I drove hard, pushed like hell.
1 1/2 hour later, pushed like hell: 11 laps, all 4x 1:19 4x 1:20 and 1 1:21 (Traffic).
Same driving, not more confidence, either the car slides or it does not..
So, here is the confusion with your claim. It can be your driving. You woulnt be the first one to be surprised one way or another with your time at the track. slower or faster, with NO changes how many of us has has a 1 second slower or faster time. With me, and the tracks i visit, i can usually predict within a .5 second or so, before I see the sheets. but recently, i had a huge improvement, and dont know why. think it was me! also had a slower time that I thought was on a lap that was in the usual range. you cant go by seat of the pants. you go by your markers, and watch it on video or analyse data.
Now, does a splitter and a wing help with lap times? certainly! more at some tracks than others.
Does a gurny flap provide 1 second beter laps times?? certainly NOT. we already have gone over what its effect is. ONLY if you have maxed out the effective angle of your current wing, does it pay to use one. otherwise, you are dealing with 25% more drag for the same rear downforce. make sense?
What you are really saying is that you bolted on a gurney flap and gained 1 second. this means you are really saying you increased the angle of your wing from 5 degrees to 12 degrees and saw a 1 second lap time. both would give you the same effect. (wing angle change or gurney flap added) Is it normal to see 1 second a lap changed from a 7 degree wing angle change?? I suspose you could if the wing was not producing enough downforce and you were skidish around some high speed turns at a big fast track.
The point is, you probably didnt see 1 second from the gurney flap alone. it was more downforce in the rear. how much, it depends on the wing angle. (I have a cup car wing and I know the downforce at many different speeds through testing). You more than likely just hit a hot lap that you nailed .
the only way you will know for sure, is to look at the data, and /or pull it off, run as hard as you can and see what you run timewise.
another big factor as I mentioned, is confidence. if you are not confident, you will run 1 second slower, regardless if the car can do it or not. 1 second a lap is an eternety. if someone pulled something off my car and said , go run a flier, it would be a few laps before I trusted it fully. on the same through, if someone added something that was said to make me 1 second faster a lap. I would push even harder and probably go faster . placebo !!
If anyone is interested, here's a study that you may find interesting.
http://www.aoe.vt.edu/~mason/Mason_f/AIAA2007-4175.pdf
http://www.raes.org.uk/pdfs/2800.pdf
The study you quote seems more interested in T-strip results.
Scott
Admin
This would seem to be more specific:
Scott
Scott
Thanks Scott! Excellent find.
This one has some very interesting tables with angles of attack.
And a similar conclusion.. "This leads to an optimum
height equation that enables the efficient optimisation of any
constant-chord aerofoil."
Now we just have to find this optimum gurney height for our cars and call it a day..
in looking at the article. same conclusions for the most part. however, there still seems to be more drag associated with the gurney flap, for a given lift coefficient, which would mean, only use it when you have maxed out the wing you have in AOA.
their tests also show the 5-6 degree AOA equivilance based on lift with use of the GF.
I also like the optimization of the GF height based on speed.
net net. if you are not over 10 degrees AOA, then you dont need a GF.
got no wings and racey lookin stuff on my lowly Carrera S...so no dog in this fight.
How is it an efficient optimization if the same lift setting wth the GF equates to more drag? There is optimum GF hights, but thats based on target speed range, but doesnt change the basic results of the tests.
I just thought of something. maybe the GF can increase downforce at the slower speeds, but because the angle of attack is lower, at the higher speeds there might be an advantage over a wing that has a higher angle of attack for the same downforce. Ill have to look at the curves some more.
I have one actually that came with my cup wing. Ill have to do some experiementing with it. Its a 3% GF.
mk
mk
Cup lover! : )
Here is a quote for the link I provided:
"The experiments have shown that as long as the height [of the Gurney flap] remains less than the thickness of the boundary-layer at the trailing edge, the additional drag [added by the Gurney flap] will be negligible..."
Saying that Gurney flaps are only useful when you are at high AOA is just plain wrong.
Finally, I don't see how some 928 driver on the left coast can make definitive contradictory statements regarding what someone in Florida saw in lap time improvements when adding a Gurney flap and splitter to their aero package. That's just plain arrogant and has no place on this forum!
Scott
Scott
