DE PSM Question
I'm in....
^ Not sure the OP is asking the question from the Instructors' perspective. I assumed he means as an advanced driver able to make his own call. Could be wrong, tho... Chime in/clarify OP. If Instructing, one would always want it on, no question/common sense.
BTW your car is BEAUTIFUL!!!
Re: Car: Thank you!
^ The 'car' comment was to jscott82 whose car-avatar I have always lusted after. That said, yours is beautiful too!!
Thought I understood your query. Good info above. You need to 'wean' off the same at some point. Take it slow and be sure you can 'feel' whats going on beneath you before ramping it up. Don't be afraid to hire a Pro Coach - $ well spent once you get relatively proficient.
GL!
GL!
This is great stuff. After a coming up through the ranks in a 993 and a 964, I had to learn car control (albeit easier than pre 1990 911's) and I am thankful for it. I had to learn car control, trail braking and how to drive a momentum car without the electronics while driving amongst the 996's, 997's and GT3's. This will be my first season in my new to me 997S and am really looking forward to some "incremental" driving. What I mean by incremental is I want to know where the edges are, learn this car's balance, how to rotate it confidently, how to use the extra power and hopefully not to color outside the lines. Then, I will turn on the PSM - maybe.
My initial thoughts were to turn it on from the beginning - as an outcome of totalling my 964 at The Glen last September. I was thinking that the extra protection would help. In the end, I believe that having the electronics just will allow me to make more mistakes. These mistakes just don't just happen but they slowly creep in - no matter how astute I think I am about what the car is doing.
Just my 2 cents. Nonetheless, hope to see some of you out there on 3/19-20 at T-Bolt (if the snow melts) and/or on 4/7 at Lime Rock. Look for an arctic silver 997S #918.
I have seen this scenario several times: A student learns with PSM on. He then solos. With each outing his confidence builds as does his speed. He thinks he's pretty good now so he turns the PSM off. Then he crashes.
Professional Racing and Driving Coach
Basic Site Sponsor
Basic Site Sponsor
Or a relatively new driver goes and buys a GT3 because "it's the best track car out there" and stuffs it. The wheel constantly gets re-invented.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
On track when anyone ask me I give them the same answer I gave here.... Leave it on and USE IT as a tool like you would your data (as they wouldn't have data anyway).
For those cars equipped with Porsche Stability Management system, what is the consensus about running a DE with it left on or turned off? If turned off, when in a driver's learning progression is that recommended and what perceptible differences might the driver expect to encounter? I understand that some systems such as ABS are never completely disabled and will continue to intervene albeit at higher threshold levels than normal. Thanks for any insights,
As you will start driving more aggressively you will notice how and when PSM light engages - if you overthrottle exiting the corner of too much braking on entering - so just use it as an indicator of your own mistakes. when this indicator will remain silent where you want it to be silent and will pop up where you expect it to - that is a moment to turn this 'please save me' feature off.
I am not sure if regular DE session really has to be pushed that far, I would prefer to have PSM on most of the time.
it shows in pretty much each and every thread on this forum.
