Coilover Advice
Old 12-18-2010, 04:38 PM
Bill Lehman
Bill Lehman's Avatar
Default Coilover Advice
I'm looking for a set of coilovers for my non PASM Cayman S. It is a street driven DE car with GT3 LCA and front bar, Tarett rear bar, and recently ordered Rennline rear toe control arms. I've rejected JRZ and Moton because of cost and complexity. My choices seem to be Bilstein PSS9, KW Variant 3, or Sachs. Sachs are new to the market and I can't find out much about them. Any knowledge on any of these products would be appreciated. Thanks.
Old 12-18-2010, 05:00 PM
333pg333
333pg333's Avatar
Having used the KWs for some years now I am sure you won't be disappointed if you choose these. Excellent for a dual purpose car. They really do ride extremely well over rough or irregular surfaces and undulations. You can run quite high spring rates too if needed and you don't drive around town with regrets. They have great high speed release valving which affords them a 'cake and eat it' status.
Old 12-18-2010, 05:05 PM
93 FireHawk 968
93 FireHawk 968's Avatar
I have Moton CS's and they aren't cheap but not at all complex. Pretty easy to adjust, dial where you want it. The costs for Moton's has dropped a bit since I purchased them 2 years ago.
Old 12-18-2010, 05:36 PM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
C'mon Bill. Go for the Motons. You know that you're a tinkerer and besides, I'll help you.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 12-18-2010, 06:41 PM
Land Jet
Land Jet's Avatar
I bought the PSS9's first and found them too lightly sprung for my car on track. Bilstein was no help when I tried to upgrade the springs. Then upgraded to the Moton Clubsports with a stiffer spring package and that has done the trick.
Old 12-18-2010, 10:24 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,662 Likes on 856 Posts
Sachs is a very good damper, and is (I believe) standard on GT3 Cup cars. KW is also pretty decent with the proper springs.
Professional Racing and Driving Coach
Old 12-19-2010, 12:08 AM
altonj
altonj's Avatar
I run KW V3 on our non pasm cayman S. They are great dual purpose set up. I am sure you will like them. Consider some camber plates or GT3 control arms for the front....
Old 12-19-2010, 04:03 AM
FTS
FTS's Avatar
My first choice would be Motons, and second Sachs. Sachs were the dampers on the RS Spyder and spec shocks on GT3 Cup series cars, superb quality.
Old 12-19-2010, 09:21 AM
consolidated
consolidated's Avatar
I had KW V3s and then KW Clubsports on my Cayman S, both worked well. The KW CSs have more damping and significantly stiffer springs, they weren't very comfortable on the street, the car staying the garage more but it was slightly quicker at the track.
Both were better than the Bilstein PSS9s on my Spec Boxster. The KW's are two way adjustable, but be aware to getting to the upper adjusters requires a few hours of work removing the trunk's interior to get to them. I finally cut a 1" hole at the rear shock mount interior trim panel and put a cover plug over it.
Old 12-19-2010, 02:53 PM
pantera43
pantera43's Avatar
Could someone direct me to a 964 spring rate chart for the KW V3's and Clubsports? I've exhausted the internet and Rennlist forum. For the life of me cannot locate this data.
Many thanks,
Dan
Old 12-19-2010, 03:15 PM
jrgordonsenior
jrgordonsenior's Avatar
PSS10's are a completely different damper than the PSS9's at about the same price $2,500). I was very impressed by them in the 996 Spec series. We revalved them ($600.) to match 700/900 spring rates. I believe they come with 250/375 (+/-) spring rates which would be a nice upgrade from OEM but not too stiff for a street car.....
Old 12-20-2010, 02:46 PM
Bill Lehman
Dan, for KW spring rates check this link:
http://www.eshocks.com/bil_veh4.asp?...=All&SubChar=Q Bill
Old 12-20-2010, 02:53 PM
utkinpol
utkinpol's Avatar
JRZ RS dual adjustable with no external canisters - $3200 for shocks, Eibach double springs kit with tenders - $800.
Old 12-20-2010, 04:12 PM
pantera43
pantera43's Avatar
Thanks Bill! KW seems to have some weird spring rates? Soft in front stiff in rear compared to other vendors. Also the split difference form frt to rear seem to be wider.
Dan
Old 12-20-2010, 04:47 PM
utkinpol
utkinpol's Avatar
Dan
none of KW or PSS come with 600+ springs and after one counts in the price to get the re-valved it becomes clearer how JRZs and Motons prices were set.
so unless one will get PSS10 kit how it comes with kit springs it makes sense to get JRZs. PSS10 kit springs are single 450/600lbs if I am not mistaken with no tenders. cayman will probably want close to 0 split from front to rear as it is 50/50 car so, there is definitely something to think about there.
Quick Reply: Coilover Advice
