Stacker Breaks Loose From RV Last Night....
down the grapevine!! wow, that is very lucky. For those of you that dont know that piece of interstate 5, that is a 4000ft down to near sea level in about 15mins.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Aa a "kid" working for my Dad's company I was up and down the Grapevine a lot moving heavy equipment. I had some scary moments going down that thing.
Some pics. When I crawled under the rig Saturday morning I was stunned to see how small the entire hitch assembly was. Still can't believe it's rated for 15k with WDH which he was using. Notice the spot welds on one side of the box. We had to grind off the RR hinge and it took 4 guys to pry that door open....
![](http://img502.imageshack.us/img502/8174/ciddsc00221.jpg)
![](http://img132.imageshack.us/img132/6208/ciddsc00220.jpg)
![](http://img695.imageshack.us/img695/8548/ciddsc00218.jpg)
![](http://img259.imageshack.us/img259/1791/ciddsc00217.jpg)
Mr. Excitement
Cold contaminated weld on right (image) side both the box tube and back plate. The weld root on the back plate is too small for the materal being mated. This would have beea goos area for a pothole weld through the back plate. I bet the cold weld was the start of the failure and led into the small root of the backing plate. It cracks loose during a hard flex and is the stress riser for the rest to follow.
The surfaces of both areas are rusty and there is signs of a older split in the metal of the angle iron added to the front of the box tube. Look a the rust on the ends of the failed area of the angle iron. This all started some time prior to the full failure and might have been visable during an inspection. Overall the hitch box tube weld work seems too light in build and poorly done on top of that for the load rating for my comfort. I might be inclined to fish scale the flats and corners. I would also look at the rest of the structure and add other reinforcments as needed during the repair.
Although something may be rated at 15,000 lbs or so, that's just the tow capacity of the tow vehicle, not the weight limit on the hitch/tongue. This should be more like 10% of the load, from what I understand. I think this is the precise reason for weight distribution hitches.
You guys have a lot more experience than I do at this, so I might be missing something here.
Glad to hear everyone's okay. How's the cup car?
Mr. Excitement
Weight distributive hitched often put more strain on a receiver tube not less. Regardless of the hitch type used (5th wheel aside) everything goes through the receiver tube.
![](http://img192.imageshack.us/img192/7958/ciddsc00219.jpg)
