Completely stripped down ready for transformation from 944SuperCup to GTS3/GTS4
#47
The one part that was hard to source but is resolved now was the lexan windscreen, which is supposed to be here any day now.
#48
The dash bar was installed today, this will privide a place to mount the brackets needed for the dash. A little trimming around the steering column is needed so the dash can sit better.
#50
fiber glass hood, nose piece
I saw the new fiber glass hood, sun roof and nose piece today. Very nice quality, they came from AIR. Some pic's I took today.
#51
#52
Cage reinforcing work
John installed today some of the extra reinforcing to the cage. He has so far boxd out the monting points/ added a diagonal that goes up on the drivers side /added a roof bar/ added a dash bar/ new passenger door bars and some corner braces. Tomoorow will be the driver's side nascar door bars and the bracing to the front struts.
#53
Really looks good Gary, and as the last time I saw you your car was in an "unhappy" position at the Glen i'm sure your take safety very seriously.
#54
Oh yeah! After being trapped in the car up side down for what seemed like a long time I decided no more insufficent cages. My helmet had 7 separate fractures in it from where the roof caved in. Thank god my seat was set as low as possible and I'm not that tall.
#56
Could you slow down on your build progress Gary. I'm getting whiplash here!!
#57
100% agree on that, ever since then if my tyres got too hot and started to slip away I've slowed the hell down!
#59
Gutted door
The doors are gutted, everything removed except the door bar.
Holes were drilled along the bottom of the doors for a little extra weight savings
Mirror removed ready to be replaced with more aerodynamic ones
#60
This is a JME motor??
