Are Pagid RS29 in intergalactic backorder or something?
Trying to locate a set for widebody/turbo brakes for the event at Laguna in a couple of weeks.
I guess I can go the RS19 (black). I have RS44 on the car now and I'm not fond of them at all.
Any ideas?
TIA
Any ideas?
TIA
As we sell Pagid Pads I can tell you that (dependent on where you shop) RS29's are going to completely replace the RS19's. While the RS29's are a bit short in supply (again dependent on where you shop) in many of the shapes. We have the rears in stock (as well as other sources), while the fronts are on order from Germany. As I understand many of the suppliers are in the same boat....
GT3 player par excellence
joyteen, i'll see u at LS this year then.
no way, RS29 out again. why is it so difficult for the car industry to keep things in stock? i am out. i need them for LS or else i will have to use other's rear bumper to set up my turn in.
Check with Northstar Motorsports. They keep a pretty good supply of Pagid's. www.northstarmotorsports.com
Just checkin' to make sure.
The RS29 in the U2474 shape (for your 996 Turbo/C4S front calipers) are on order. We have plenty at OG Racing of the RS19 version of the yellows in stock as well as for your rear calipers which is the U2405 shape. The difference between the two is that the RS29 have slightly more initial bite that the RS19. Both are very rotor friendly and do help to reduce caliper temperatures. The Pagid importer told me a while back that most of us club racers and DE guys would be hard pressed to tell the difference between the two.
Call Ilker at sportscar boutique. Canadian distributor. 905-731-0700
Won't be super cheap with shipping and duty and whatnot but his stock is usually really good.
We have the 2474 in both the 19 and 29 compounds in stock.
Your Porsche Parts Superstore
![](http://www.paragon-products.com/v/vspfiles/assets/images/pagidrs2.jpg)
![](http://www.paragon-products.com/v/vspfiles/assets/images/Paragon web logo.gif)
![](http://www.paragon-products.com/v/vspfiles/assets/images/konilogobkbgsm.jpg)
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
