Smarty Cam booting problems
I got it with my 1st camera and still get it with this one, but ONLY on initial startup (with both). When I get it and don't reset, I get no GPS function. It never kicks off once the camera has started, just does it as I described at startup..
Hey Rick! How ya been!
I too am having some problems with the smartycam connected to my mxl. While the cam sees the GPS signal fine, the data logger is no longer getting gps triggers. Total loss of all track data. (well, one big lap). I tried reseting the gps beacons, but it didnt work. Its really pissing me off that the simplest configuration doesnt work. These guys seem to know how to build hardware, but the software, particularly the drivers and connectivity is garbage.
I've had my MXL since they first arrived here, but I'm getting really close to sending the cam back, selling the AIM and moving to a new system. Really a shame as if it actually worked as advertised, it would be a great system.
to Gary - i troll in one thread at a time only, so this one is serious.
Now that I look I see I purchased the AVS Editor and the converter is a different module in the "AVS4YOU" package, which I haven't a need for. The Editor works great for my needs but if you own a high end program like AVID you may just try the converter to see if that allows you to import it. Not an ideal situation but a possible solution nonetheless.
I guess I'll give it a shot, assuming I ever get the gps to work with the mxl, but its annoying to spend more $$$ as I already own two editors, Vegas and some other cant remember what it is. If their format is non-standard, they should ship a converter as part of the smartymanger software. It is ridiculous that we have to buy a converter as well IMO.
or if it does i did not see it yet.
nice butthead picture you found, i sa it long time ago somewhere. i promised myself not to post into that thread anymore, but wanted to comment.
What, are you saying I can't just go blindly ahead and update?!
I was hoping this would fix everything.
I can still hope, right?
To their credit, AiM has provide great response to support requests. it works best when they are called in, though, not emailed.
I shall continue to persevere, but I may have to learn some Italian swears (Doc, you gonna help me here?).
