Smarty Cam booting problems
Big problems with SmartyCam after firmware updates.
Smarty won't complete boot; 95% of the time it hangs at splash screen or gets into starting screen but hangs there.
I updated firmware via Smarty Manager. Trouble with communicating with Smarty so update is via card that came with the SmartyCam. Firmware is 01.01.02.
Smarty will almost never communicate via USB with my laptop, despite continual unplug, reboot, replug. Works occasionally, then no longer.
Is there a way to reset to factory defaults?
If we can't get this fixed, can I plug the GPS directly into MXL and at least restore this capability?
Thank you; I really need a hand here.
(above is the message I just sent to AIM; posting here in case anyone has suggeestions)
Sounds like the firmware update got corrupted somehow. If possible try loading the previous version back on there first. Then I would re-download the latest firmware and try to run the update again. I assume you have the latest Smarty manager installed and the newest USB drivers..
They should pay you for providing me the technical support.
I updated the firmware because a few weeks back the dash would cut out then reboot (on the track, flashing me an error message something like SLAVE NETWORK LOST, though its hard to remember as I was hurtling down the track).
I tried a new download and reinstall of the latest firmware, but let me roll back a version and see.
I'll let you know.
Isn't this stuff supposed to be consumer friendly??
Where can I get latest drivers? Windows 7 tells me it is up to date but I wonder, as I have lots of communication problems with Smarty (which needs a new name).
Rick, at risk of stating the obvious there're two sets of firmware--one for the main processor and another for the slave. The May 18 update requires both to be installed, first the slave and then the main.
One of the dealers will have to chime in on a "hard reset" method--I don't think that's an option in the built-in menus or the SmartyManager/RaceStudio.
Spoke with AIM this morning and they are replacing the unit; though I would have preferred that it not need replacing, they were very good about it and have a new one coming overnight.
New SmartyCam received as promised by AIM. Worked fine at Mosport although I am having a bit of GPS problems (first 1/2 of session no GPS signal so no speed or time info, then during the 2nd half all of a sudden GPS is back).
I suspect a bad cable and am talking with AIM about that now.
Rick
I wish you mentioned your problems when we talked at Mosport. I had spare camera and cords at the track. Send me an e-mail at jandsaustin@verizon.net if you have questions or need assistance with AIM or Smarty Cam. I may not solve your problem but it may help me with solving others later, I am still learning. Great weekend at Mosport huh! Do a search of a Mosport lap in a 964, I just posted a lap (not me driving though).
Rick - also be sure you don't see (you have to look for it) "Slave Net Error" across the bottom of the Pista screen when you start up. I believe, though not sure, that it is tripped because the camera hasn't started yet and the communication isn't there. For me, I turn the key to "on", power the Pista and wait to see if I get the error or my regular "Oil Pressure" message. If I get the error I wait a few seconds (with key on) and try again. As soon as I get no error I continue turning the key to start the car and all is well.
Rick
Kind of you to offer; you were way to busy for me to bother you about this.
AIM ended up replacing the camera. The original problem posted here was that I was getting this Slave Error message on track at Tremblant (a bit hard to remember the exact words as I would see it at speed). We concluded a replacement camera was needed which AIM supplied via overnight.
That new camera solved that problem, but I am now having a problem where the system will go a few laps without picking up GPS, only to find the satellites and begin logging. So I might get half a run of no GPS (and therefore no speed or times) then all of a sudden I get it.
AIM is looking at logs files now to tell me what's next.
I suspect a bad GPS antenna or cable, based on the intermittent nature of the problem.
I'll keep you posted.
What would happen is that the whole dash would flash the shift lights, shut off (could be the wrong sequence here) then come back on with that error message.
Very entertaining at speed.
