Dry ice in cool suit?
DP, thought the same thing. Would love to hear thoughts on dry ice.
I gave up the look for reasonable peltier coolers. Wife frowned on my idea of opening up her wine fridge to "see how it works"
Lets see, dry ice, gotta have some liquid for the cool suit, sealed container because all the cool suits run them. I would have thought that combo was enough to predict the outcome but I guess not.
I quick search on youtube showed this one,
http://www.youtube.com/watch?v=Wf9GW...eature=channel
I personally found it entertaining to watch for a couple of reasons, watch thru the end for the bounce to get the full entertainment effect. - You should like this VR !
But since the races are "sprints" I guess it doesn't matter....most coolsuits are rated for 2-4 hours right?
In an open car I seriously doubt it would be an issue, and the gases go to the floor, but I still wouldn't risk that one either.
Seriously, if you really want to keep it colder longer try adding rock salt. Also use larger chunks/blocks of ice. Tupperware can help make DIY large chunks of ice if you can't find block ice where you live.
Want the water colder ? Try a very small amount of rubbing alcohol to a large volume of water.
even if you vented the lines, you might just freeze all the water and get no flow.
What you really cold do, is get a big bubble suite and use the cold Co2 as air conditioning and calll it a cool gas suit.
How about venting it out the back of the car into your competitors air intake !
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
