Video from Maverick PCA DE at ECR 5/29/2010
#47
Yeah, Loren, 7&8 need some work for sure. I appreciate you sharing the data and videos!
Dave, were you out there last week? I was looking forward to seeing some video of you at ECR.
#49
I am not familiar with the dynamics of the GT3 except a few passenger laps last trackday. This was in a well setup car on slicks but very convincing all the same, however have you changed your neg in the front from stock setup, and what about toe? Has your car been lowered a bunch?
How about taking an earlier apex but trail brake which should help rotate the rear? Might be worth a try.
#50
If you watch the videos, I do trail brake and it is very noticeable in certain corners: T3, T10 and T11. I have not lowered or corner balanced the car. GT3s come setup fairly low already from the factory. As the front spoiler, brake scoops and side deflectors already scrape I have no desire to lower the car further. I may corner balance it tough. I don't really want to toe it out. I tried that in my previous Carrera and I didn't like the high speed wantering that comes with it. Given the greater power of this car and trying to put that power down I am even less inclined to want to add toe. I know of several things that can easily help, most noteably tires. If I switch over to running Hoosier R6s, Goodyear or Michelin slicks I will gain a lot of grip. Right now I am going to keep driving the Corsas and see where I can get with them.
#51
Without the front bar set full soft, I could not hit an apex to save my life as it simply would not turn-in.
#53
I enjoyed ECR. hope to get back there this year.
#54
If you watch the videos, I do trail brake and it is very noticeable in certain corners: T3, T10 and T11. ...
It looks like you are late apexing all of the turns, including the U-turns. If you start your turn in a little earlier, while trailing in, the car will rotate better and you won't experience the understeer you mention. Even if you don't trail in, you will benefit from turning in earlier and crisper - since the later you apex a corner, the slower you must enter it.
IMO, it doesn't look like you trail much, if any. For example, in the video "Saturday 1st afternoon, Pt 2," at 1:23 - going into turn 3 - it doesn't look like you trail brake at all. Rather, you brake pretty deep, and transition to gas when you turn the steering wheel. You can see the tach drop, and hear the gas kick in at 1:25-26 right when you turn the steering wheel (same at 3:25+). Same thing at turn 6 at 1:55 (and 4:02+) - you are on the gas right at turn in. Ditto turn 11.
Also, you saw the wheel throughout most turns - which upsets the chassis. And, you back out of the gas a couple times in each corner, which also upsets the chassis. I'm sure you've heard this many times, but you should be on full power at the apex. If you listen to the "soundtrack," you will hear that you get to full power closer to track-out all around the course. I even heard this at turn 2, where you got to WOT at track out - but you should be on full power before the T2 apex if you do it just right, but no later than the apex regardless. Basically, this means something is not "right" at corner entry through the apex if you have to wait until track out to get to WOT. You either need to get the car rotated earlier, or give up a little more on the entry. Especially in turns 6 and 11 where you want to be on the gas ASAP.
I know this may sound weird, but IMO you are using the steering wheel way to much to turn the car through a corner. You should have a steering input at the beginning of a corner, and then very little (if any) after that. You might try leaving the steering wheel locked and trailing your throttle to rotate the car - not back out of the gas, just rotate the car with the a trailing throttle. This will require going through some turns a bit faster even so that the car can be rotated in this manner. But faster is a good thing
Lastly, a GT3 with the rear bar on full stiff, front bar on full soft, AND under trail braking should not understeer and miss apexes unless something else is amiss.
-td
#55
Lemons #3 civic... 2:15's?
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#56
I finally had some time to look at some video, the data plots and this thread. First off, you are driving the car pretty fast. But, IMO, there are a number of fundamental things you could alter to get a boat-load more time out of the car. Please don't think I'm trying to be an ***, I'm just tossing out some thoughts. If you don't think any of them are worth squat, no worries.
I know this may sound weird, but IMO you are using the steering wheel way to much to turn the car through a corner. You should have a steering input at the beginning of a corner, and then very little (if any) after that. You might try leaving the steering wheel locked and trailing your throttle to rotate the car - not back out of the gas, just rotate the car with the a trailing throttle. This will require going through some turns a bit faster even so that the car can be rotated in this manner. But faster is a good thing![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
-td
-td
http://www.davidmurry.com/pca-videos...anyon-may.html
Watch some of the better drivers like Jim Buckley and Rocky Johnson. You will notice they both give throttle and reduce some steering to get widen their arc. Both give more steering input and a light lift to turn to hit the second apex. You will also hear (and watch the G meter) both not get hard on the throttle until almost track out. Also watch what they do for T11. Buckley brakes more and enters slower to get on the gas earlier in the turn while Rocky carries more speed in and stays neutral until he gets closer to apex when he puts throttle in. Both do this as there is a lack of grip in the center of T11. Finally, if you want to really see the difference tires make; watch the last video of Doug Bielefeld in his GT2. He is driving on Michelin Cup racing slicks (not MPSCs). That is a car that was hooked up.
#57
That picture is not me, it is Doug Bridges. He is the one I was passing in several of the videos. I was driving the other black GT3 (#984). We do have similar number sets as both were made from the same pattern by Blair. Quick ways to tell us apart is my car has bi-xenons while Doug's has dynamic cornering lights. I have sport buckets and Doug has 996 Euro GT3 seats. I don't run a tow hook on the front. Doug's car has a silver GT3 emblem on the back while mine is black.
#59
NASA Racer
All 911's push. I like mine to push a little because I like it to feel more stable on the sweepers and then use trailbraking in the slow turns to rotate the car. But, real trailbraking is hard to do and requires you to be on the edge and comfortable with catching the car when it comes around.
YMMV
#60
The Penguin King
