Home Car Lifts
Home Car Lifts
There are a lot of car lifts out there now. I searched the forums and the last post I found was in 2008 so thought I would ask given the 2 year lapse.
I have a regular two car two door garage. My ceilings are 10' so I don't think I will have an issue. My main reason I want the lift is for storage...I have 3 cars and a two car garage...I wouldn't mind being abot to change wheels but that is not my primary reason for the lift.
From my short research, it seems a 2 post lift is the most popular. However a 2 post lift may make it difficult to exit the 2nd car (underneath) when pulling in the garage. So, my dilemma is two fold...
1. 2 or 4 post lift
2. Which lift to buy (US made only) for my situation.
Anyone in the MD/DC/VA area have any experience with a local installer?
Thanks!
Will
1. 2 or 4 post lift
Thanks!
Will
Super Moderator
Needs More Cowbell
Needs More Cowbell
I would suggest considering a single post lift.
Very low floor loading, takes up minimal space, excellent storage lift solution IMHO.
http://www.bowlinent.com/lifts/duplex_lift.php
http://www.northerntool.com/shop/too...&ci_sku=177808
http://www.asedeals.com/single_post_storage_lifts.html
http://www.interstatelift.com/inters...m_one_sing.htm
I have a 4 post, originally just for storage, but bought the bridge jack. If I move its going with me. Even for the little things, I just put the Carrera script on the car today, having it 3~4ft off the ground made things so much easier.
Wow...I never considered a 1 post lift. That add a whole new dimension to my process....could I get a 1 post lift and still be able to change wheels? Most of the 1 post lifts in the links you have to drive on...
The 4 post lift seems to be space consuming.
Very interesting.
Any other thoughts?
Very interesting.
Any other thoughts?
A 4 post lift is the best solution for primarily storing cars and occassionally working on them. We've installed several for clients we've built homes for.
A one post lift requires the concrete slab to be in very good condition...i.e. do you absolutely know the construction of your garage slab???
Super Moderator
Needs More Cowbell
Needs More Cowbell
A one post lift has the lowest floor loading of either a 4 post or 2 post lift; simply based on the area of the mounting 'foot'.
In fact, they can be installed outdoors on asphalt, as is often done in Europe.
Super Moderator
Needs More Cowbell
Needs More Cowbell
The full 'floor' is also nice since it will prevent the car on top from dripping (oil, fluids, etc) onto the car below.
They can be assembled and installed by 2 men in about 4 hours or so.
I have a one post lift from Bend Pak. You cannot change the wheels with it but there are removable center panels that would allow you to do other work on the car. It's perfect for my needs as I just wanted to be able to store the car in the garage using minimal space. I use the jack when doing brake work/changing wheels etc.
I dunno about the four hours....mine took three guys a full day and they weren't screwing around. The post alone weighs 1,200 pounds.
Dang three Porsches! And my wife says we have too many!!
Well, I have a traditional 2 car garage where if you have 2 cars in it, you are lucky to get anything else in it. Cost is always a factor (no lotto winner here). I would like to know if anyone in the DC metro area can recommend a shop that can come and look at my garage and make a recommendation based on my space limitations.
Thanks!
Thanks!
Super Moderator
Needs More Cowbell
Needs More Cowbell
I have a 2 car garage with a single post lift. There is zero additional floor space required, it is simply a matter of ceiling height. In my case, there was a carrying beam running across the span, so the lift is positioned so that when the car is lifted up, the beam ends up in front of the windshield by the hood, allowing the entire vertical height to be used.
You should be able to determine for yourself based on the available ceiling height, the height of the cars and the drawings for the lift.
GT3 player par excellence
ps. How many more car hoist / lift threads do we need?
https://rennlist.com/forums/997-gt2-...ght=hoist+lift
https://rennlist.com/forums/928-foru...ght=hoist+lift
