Looking for recommendation for engine hour meter
Old 04-20-2010, 08:56 AM
JoeMag
JoeMag's Avatar
Default Looking for recommendation for engine hour meter
Anyone have recommendation of a 12V engine hour timer? ...something that when it see's 12V it times? I have msd ignitions with rpm switch and was going to put module on so it signals (times) above 3.4k or maybe 4k rpm.
Old 04-20-2010, 09:11 AM
Circuit Motorsports
Rennlist Small
Business Sponsor
Circuit Motorsports's Avatar
http://www.pegasusautoracing.com/pro...asp?RecID=5519
This is the one I've had on a car in the past. Never any issues with it.
Old 04-20-2010, 10:29 AM
jpk
jpk's Avatar
Check with a local lawnmower shop or a place like Northern tool:
http://www.northerntool.com/shop/too...-meters-gauges
Old 04-20-2010, 11:12 AM
J richard
J richard's Avatar
Hobbs meters are the best bet, you can get them at graingers in the round dash housing or just the meter if you want to tuck it away...
http://www.grainger.com/Grainger/ite...Meters-_-2A644
Old 04-20-2010, 11:35 AM
Toby Pennycuff
Toby Pennycuff's Avatar
I had a Hobbs meter integrated into my VDO tachometer. It's located at the bottom center right where the boost gauge is for a 930 turbo. The gauge is triggered by an oil pressure sensor when it reaches 10 pounds of pressure. This keeps the gauge from running when the ignition is the only thing that is on - in other words the setup is designed to provide a true representation of engine OPERATING hours. The Hobbs meter integration was done by North Hollywood Speedo and they did a GREAT job. I'll try to remember to take a picture and post this weekend.
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
https://www.sendec-products.com/xcart/home.php?cat=249
Old 04-20-2010, 01:26 PM
Cory M
Cory M's Avatar
I just got a simple one from West Marine for my last racecar. If you have a data system like Motec or AIM you may be able to program it in...
Old 04-20-2010, 05:43 PM
911racer
911racer's Avatar
Doesnt your dash do that. I know my mxl does. (have not figured out how to reset it yet) (or looked for that matter)
Ed
Old 04-20-2010, 05:48 PM
Geoffrey
Geoffrey's Avatar
I use one from ENM (Allied Electronics carries them) which is digital and resetable. Hook it to your fuel pump relay.
Old 04-20-2010, 07:07 PM
bgiere
bgiere's Avatar
Joe, running this one on the 944...easy to install, reliable.
http://www.yamaha-motor.com/waverunn.../0/detail.aspx
Old 02-15-2011, 02:35 PM
Phokaioglaukos
Phokaioglaukos's Avatar
What do you think of this one? Runs on an internal battery and only counts when there is vibration, so leaving the ingnition on is not a problem and no need to plumb into an oil line for an oil pressure sensor to detect engine operation.
http://www.aircraftspruce.com/catalo...mhourmeter.php
Old 02-15-2011, 03:01 PM
Mahler9th
Mahler9th's Avatar
I wonder how reliable that would be in a car as far as the vibration on/off circuits. Probably pretty good if used in aviation.
In some ways it does not matter as long as it is consistent and the accumulated hours mean something to you.
I still prefer the set up that uses a Hobbs or similar that gets 12v or ground (you pick) from an rpm switch set at some rpm level you find meaningful. I rigged this up in my car 5-6 years ago. The rpm switch was a cheap generic from Summit and the set-point in my case is 3k rpm. Easy and cheap.
And consistent behavior in terms of on/off.
Old 02-15-2011, 05:15 PM
MUSSBERGER
uninformed gas bag
MUSSBERGER's Avatar
We use to have those on our small equipment (rollers,compactors,pumps,generators,etc). Seemed to do the job.
Old 02-16-2011, 06:21 AM
Phokaioglaukos
Where did you pull the tach signal and where did you mount the hour meter?
Old 02-17-2011, 12:23 AM
Musche
Musche's Avatar
The vibration activated ones will count when you are towing a car in/on a trailer and you won't want that. They start timing by cutting a jumper wire and will stop timing if the wire is reconnected either by a switch or normally closed relay.
Quick Reply: Looking for recommendation for engine hour meter
