I need a trailer!
Not a bad thought Glen. In fact, the Boxster has no windows, so I was going to have to deal with that problem anyway. My concern would be the towing capacity. For the Audi Q7 it is 5500 lbs. The car is around 2,500lbs, plus let's say, 500lbs of stuff. So if my math is correct the trailer would need to weigh less than 2,500. Can I find an enclosed trailer under 2,500lbs?
http://www.trailex.com/CTE-80180.cfm
According to their website, total GVW is 7K, and cargo capacity is 4.7K, so if my math is right, the trailer should weigh around 2.3K. This is almost half of an empty steel enclosed, and a bit more than steel flatbed. Not cheap though.
Did you see my PM?
Hey Andy. There's not a lot of good used aluminum trailers out there this Spring (at least so far as I could see). So, I just purchased a new open aluminum trailer at Performance Trailers in Flanders, NJ. Nice folks down there. Feel free to call me it you care to discuss. (914) 548-5084.
Maybe see you at LRP (still undecided on Lime Rock club race this year). Your spbox looks great, BTW.
Is that published on their website? For some reason "Trailer Weight" and "Carry Capacity" are blank on this webpage:
http://www.trailex.com/enclosed_sports_car_trailers.cfm
I made calculation based upon info that pops up when you click "Trailer Dimensions".
Peter
I would disagree, having pulled the open and enclosed the enclosed always pulled better. And I mean easier behind a Cayenne, 1/2 ton Toyota Pickup, 1/2 ton chevy, Range Rover and a 1/2 ton escalade. We have several trailers now so no shortage of choices, we just use the transporters for the races these days. if I was still pulling to the races myself. The aluminum enclosed is a no brainer, garage, hideout from rain, more secure, advantages go on and on. I had a fully loaded 24' foot enclosed also and would still pick the light alum enclosed. Just my experience, and I have had alot....
In your opinion, what size is too small for an enclosed trailer? I need to keep it light and cheap, so I want to go as small and simple as possible.
Thanks,
Andy
If your Q7 has the towing package, like mine, the limit is 6,600lbs. I have pulled a 3,500lb enclosed trailer behind mine for a couple of years. It does OK, even with the 3.6, but mileage suffers, pulling in 5th gear. I am moving to a steel 7x18, lower profile trailer that is about 1,000 lbs lighter so I'm not pushing the towing limit so much. I have an escape door in the side, which is why I can get by with such a narrow trailer, but your car would probably need at least a 7.5' wide trailer to make it work. I have 80" between the walls, which fits my 944. It's hard (but not impossible), to get out without the escape door open on the side of the trailer. My new trailer will have about 15 SQ ft. less frontal area - hopefully that will help the mileage (drops into the single digits at times when I'm towing at 65+).
The longer wheelbase Q is a wonderfully stable tow rig, with great brakes!
Here's a PDF of their race trailer line. http://www.unxpres.com/Uploads/ProductLit/Lit_52.pdf I the UXT trailer, but in a 7' wide version. About 2,600lbs, under $6K (if you don't get carried away with the options). Again, the 7 foot width may not be for everyone, but I like it because I can see around it without add-on mirrors, and the aero drag is less. I fold in the mirrors on the 944 to comfortably fit through the opening .
Glen, interesting, my experience has been just the opposite of yours. My F250 diesel pulls a 2 car open steel trailer (which weighs a gawd awful amount plus the weight of two cars), much easier than a single car enclosed which weighs a lot less. The wind resistence seems to be the killer at least for me.
Andy
There is a big difference pulling an enclosed trailer (except for the low enclosed Trailex). The wind load is a lot more than an open trailer. You can pull it short distances, but the long hauls are going to be tough on the tranny in the Audi.
