Gov't considers mandating throttle override systems
http://www.nytimes.com/2010/03/03/bu.../03toyota.html
Might make left foot braking more difficult...
What we REALLY need is better driver training. The fact that most drivers would panic when the throttle sticks rather than simply turning the car off or shifting into neutral is proof of just how poorly prepared most drivers are. I managed to make it through T12 and T1 at Road Atlanta with a 100% stuck throttle in 5th gear...surely the average American can learn to shift a car into neutral and pull off to the side of the road with a stuck throttle at 70 mph on the highway?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
BTW, most cars already have throttle override systems...it's called putting it in Neutral or Park followed by turning off the ignition...
Is it just me, or isn't the bigger issue with the whole Toyota thing that it had a transmission lockout a > 50% throttle that prevented you from putting it into Neutral?
yea i know...i test drove a jaguar xkr. that thing can brake pretty hard on its own. i wonder how they do that....a hydraulic pump the master cylinder or something?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Here's a great quote: "Without the system, a car’s computer might think a driver wants to keep accelerating, and ignore a driver’s efforts to depress the brake pedal and stop the car. Once the system is installed, it will stop the car if both the brake pedal and accelerator pedal are depressed."
How can a computer "ignore" me? What if the computer gets angry, or senses that you are going to de-activate it, and it begins a murderous effort to save itself? Cars would get together and defend themselves and coordinate development of defensive and offensive weapons with robotic computers.
PS: Audi pioneered the throttle interlock and it's only a problem if you are a two-footed driver.
King of Cool
As I've said before, instead of going "forward", I'll go backwards.
With all this government crap, below are couple of examples of what my daily driver (besides my 993) most likely will look like few years from now...
Based on what I heard in the congressional hearings, Scott's right. Above a limit speed, put the selector anywhere you like but the transmission will not shift to neutral or reverse.
A mech eng prof from Ohio testified that the Toyota ETCS used two TPS sensors that both generated the same signal [0-100% generates 0V-5V from each sensor]. Others that he had tested had two sensors that generated complimentary signals [0-100% throttle generates 0V-5V from one sensor, 5V-0V from the other]. Its obviously easier to detect a loss of one sensor signal using the second strategy, and not so much using Toyota's strategy.
Brake override makes sense, of course. It provides a strong fail-safe in the case of any throttle signal error. Cable-driven throttle systems might fail once in a while, but they have nowhere near the potential to screw up in unexpected ways that electronic throttle drives have.
Correct me if I'm wrong, but don't current Porsches already have this feature? If you press on the brake while the accelerator is also pressed, you can do about a 2 count before the engine shuts off.
For example, try warming the brakes on a new 997 and see what happens. Then you have to wait a few seconds for everything to come back to life.
Still plays with cars.
Almost all cars using the Bosch system already have an engine over-ride. Certainly all Porsches with E-gas have it, likewise modern VW and Audis. Left foot braking is pretty much hopeless unless you lift off the gas, brake and then re-apply the gas. If you brake while pressing the gas pedal,the engine returns to idle after about 1 second. I foound this out the hard way while trying to maintain boost in my 2002 GT2. Spun the car as a result.
I'm Still Jenny
Sounds silly. Mandating brake override, while allowing cars to have a neutral lock-out, doesn't get to the root cause. If the brake lockout "fails" and you can't shift out of drive, you're still fooked.
