996 GT3 cup copy classification issue
Frankly the remaining weakness in PCA GT is this concept of putting power level estimates based on a 100% motor. The GT class is already mostly power/weight except power is not determined by dyno, but the max you can make from a certain type motor with a ratio for displacement. Never before has a range from normal stock to 100% built been a consideration. It has always assumed 100% built.
Really it seem that if you are going to consider induction type as factor on the GT3 motor it should be factor for all engines and some siding factor is needed for Turbo cars.
Quite frankly, my 951 has a 200hp/L factor, and I'm pretty sure I'll never be able to have 500 reliable hp out of my engine. So in the end, it all ends up to a power to weight ratio within the specific class.
Seems to me the proper solution is to develop a GT3 engine factor and place it in GT1-6
GT3 player par excellence
If you look at lap times, you'll see that the 03-later cup cars post similar time to the best GT1 turbo 3.8l porsches. So, you really need at least one class above the current GT1 class. I agree that engine performance and weight are the only considerations in the class, but it has historically been an engine based class. I can't think of another engine where the induction system can make such a large difference in power. I consider them to almost be different engines.
A GT1 car could be a 2650 pound car with driver that has 650 wheel hp and 14in wide rear tires. A 997RSR is roughly the same weight with 480 wheel hp and same tires. I would say the chassis advantage would make up the difference in hp so they prob should be in the same class. Not really sure if 2 classes higher would be fair.
I def agree with the single vrs 6 throttle hp factor. It would help to separate the RSR's RS ect.. from the world challenge, GA cup cars.
Well by that argument if you have GT3 3.6L better upgrade it to RSR specs!
If you complain about it being too expensive that is the same reason not to contact Milledge about 500 hp 2.5L 944 Turbo motor.
Look my only issue he is that it just not right to make a special factor for the GT3 based motors due to the power range, but not consider it for 4 cyl 2.5L turbo and other turbo cars. Why give the GT3 motor not built to 100% special treatment?
