Video: please critique my Mosport lap
There is a good chance that you can't tell anything from a video, but to those who know Mosport International Raceway, do you have any suggestions based on this fairly typical lap from my first time at the track?
I'm a stone cold novice, and had never driven the track. When I wasn't letting GT1 Corvettes by, I was hovering just below two minute laps for the whole day, but I get the sense that this is overly conservative. The track was dry, and seemed uniformly sticky, except at Moss corner, where things were a little slidey once I got into second gear.
The car is a 944S on street tires.
Ha! There were only about 15 cars there, and it was a pretty lazy day. Watching the video afterward was pretty boring because you rarely see any other cars! It's just too bad I didn't know the track better to make better use of all that space.
did not watch the video, but my imediate response is to tell you not to record yourself yet and to not even time yourself, yet. Spend more time concerning yourself with the basics. Learn the rules of the road, your flags, passing procedures, and all around concentrate on hitting every braking zone, turn in, apex, and track out perfect. If you can not get them perfect, slow down until you can. If you can not do it perfect slowly you will never do it perfect fast. As with any science or art it all starts with a solid foundation of discipline.
It looks to me like several of your turn-ins are not "smooth" or "fluid" - which upsets the balance of the car as you transition from straight to the turn.
I'd focus on that smoothness first. Then you can focus more on the line. Then, should should be able to get those tires to squeal in all corners - not just 5b and 9.
I don't agree, a video is a great learning tool. With knowledgeable input you can learn a lot
Thank you for your input! I wish I'd had a chance to have someone coach me in-car, but there wasn't really anyone around that day...
Hi Charlie
Talk to Bill Newby, who has a 944 (though its a turbo) and is at Mosport a lot. Bill was a big help to me this summer during the DE portion of the Club Race.
You will find him posting here on occasion
u can def tell you're rocking back and forth at 1:35.
it didn't look like they put out apex cones on the corners. i saw mabye 2? you should be trying to at least follow the basic line since there wasn't any instructors.
Yeah, I couldn't figure out where I should be at 1:35 (turn 4). There's a lot of crown to the track surface there, and you can't see over the hill. I think I'm also going a lot slower there than it is possible to go, but I was really worried about ending up on the off-camber portion and going off!
Krystar, thank you -- that's a great resource.
...not that I necessarily have the skill to convert these directions into reality, yet, but any information will help.
[QUOTE=pontifex4;7066630]Thanks, Rick. I'll see if I can track him down in the spring!
Hi, Charlie, nice drive for a stone cold novice. I'd be pleased to hook up with you in the spring...
Meantime, here are some thoughts you might want to consider:
T1...maybe turn in a little later, and come in to clip the end of the turtles and then come further in to the wall. It makes for nice track out.
T2...come out a little more between a and b, make sure you snug right up to the bottom at b
T4...stay out a little more at the top, after coming out from under the sign
T8, 9, 10...you drove the "traditional" line pretty well, but there's a route through there that I prefer more. Peter Carrol has done a nice writeup on this here:
http://www.driversmeeting.com/forum/...ndex/581/1#648
Have a good winter
Bill
Have a good winter
Bill
Street tires should be squealing all the time (if turning). You need to learn the sound the tires make when they transition from squealing to squalling, the latter being an indication that they've washed out because you exceeded their grip. Squalling is a lower-pitched sound, accompanied with the illusion that tire barriers are getting bigger and bigger.
Have a good winter
Bill
Have a good winter
Bill
As for the Esses, I find it fascinating that that strategy could result in a faster lap, since it would seem to require you to do more turning at T10. Is the payoff that you can be smoother through the whole complex if you're not braking and turning in several times? I really want to try this.
Also, Bill, I do hope we can meet up in the spring at Mosport. With whom do you normally run?
