View Poll Results: Do you double clutch downshift?
Voters: 90. You may not vote on this poll
Double Clutch
#47
You just said the same thing for two different gears designs. (straight cut vs helical gears)
A flat torque curves is a peaky HP curve.![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
#48
Unless you had a real flat HP curve, then the spacing would only have to be the width of the max hp breadth. Some V8s with lots of torque, have these kind of curves and only need 3 gears on most tracks, and adding another one might not provide any gains. The Audi diesel was a good example of this. very wide useable HP curve.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Too many? Nope, I'd love to have more.
If you step down through the gears one at a time, you won't find yourself at such a loss at turn entry. On a modern street car transmission, only 3rd - 6th are usually able to be used on track anyway. 1st and 2nd are too low for track use. With 5-6 usable gears in a proper race transmission, the performance benefits are significant.
#49
