View Poll Results: How do you want your brakes to work?
I want high initial bite
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
14
23.73%
I want to feel some bite
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
26
44.07%
I want them linear, no bite at all
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
19
32.20%
Voters: 59. You may not vote on this poll
Brakes - Good initial bite?
I agree with your premise. I like linear braking but, I don't know that I would say good initial bite means non-linear braking. Some pads are linear but they don't have as much bite. I prefer pads that have more overall bite. But like RedlineMan points out, I no doubt brake too much.
You can always brake more softly/smoothly where that's beneficial just by softening your footwork. But for those braking zones where sufficient traction is available and max decel is required, I want a pad that takes me from peak Accel G's to peak Decel G's in the shortest time possible. If you call that "good initial bite" or whatever, fine, I'll take it.
The main thing I don't want is a pad whose friction changes over the length of a braking zone while pedal pressure is steady (e.g. because of temp).
I am happy with Pagid RS-14 Blacks. Peak Accel to Peak Decel in the 0.75-0.9 sec range when called for (and that includes the roughly 0.5 sec it takes just to get my foot from the floored throttle up onto the brake pedal).
But...to each their own.
I characterize a pad with high intial bite as one that will produce a strong braking effect with rather light pedal pressure, then additional (but less pronounced) braking as pedal pressure increases. Pads with minimal initial bite will produce a lot less braking with the same pressure as above, but ramp up braking effect with increasing pedal pressure in a more linear fashion to possibly the same resultant level. I have attached a graph to show what I am trying to explain here.
you don't just jam on your brakes in hard braking zone, you squeeze them on and ramp up the pressure.
Also, your graph illustrates that you need 400-500 more units of pressure (with low initial bite pads) to generate the same braking power. That means pushing the pedal harder, and to me this results in less feel (like gripping the steering wheel harder).
![Name: Pressure2.JPG
Size: 25.8 KB](https://rennlist.com/forums/attachments/racing-and-drivers-education-forum/382050d1251569062-brakes-good-initial-bite-pressure2.jpg)
As many have stated, I think it comes down to user preference. And probably the thickness of your shoes. Time for new poll? Does shoe thickness help/hurt your podium chances...
-td
Basic Site Sponsor
Basic Site Sponsor
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Initial bite is just a function of where on the the temp vs friction curve modified by the existing line pressures you happen to be
linearity is a function of the shape of the temp vs friction curve
most manufacturers don't freely publish theses curves, Pagid does
![](http://www.braketechnology.com/images/frictiongraph.gif)
of the pads graphed RS15(grey) will have the best inititial bite, no matter what temp the curve is always higher than any of the others, they wil also erode rotors commensurately faster
RS19 & 29(yellow),of the race pads, will be most linear, the curve is flattest
RS14(black) will be in between those choices
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
At the end of a long straight you might have one level of 'bite' while after couple of hard braking zones and shorter straights you will be at a different level.
how hard you need to push to develop x amount of line pressure is a function of the flex in the hydraulic and mechanical parts of the system, the mechanical geometry of the pedal/input rod, the boost ratio(there are several different versions) and the slave/master ratio, again several different versions depending on the model.
....and cars and driving styles and track surface and conditions and tyres and....
Too many variables, however I think we all know what Larry meant by the poll. It sounds more of a gathering of opinions rather than getting too technical from my read.
Basic Site Sponsor
Basic Site Sponsor
Exactly what I was looking for.
I agree w/ you, the problem is comparing one persons sense of the situation w/ anothers from a different car.
Orange Pagid predictable while applying near threshold pressure at the beginning of brake zone, then smooth release into corner entry. High initial bite makes sensing threshold point too narrow. Likely a different technique when racing.
+1
