Chasecam video from Carrera Cup race
To post-process it, you can purchase Dashware and make the display just like the video posted with the MoTeC display and all.
If you want the video to be sync'd (aka: you don't need to manually sync it in the post processing program) then you need to wire it up as such. Just PM me and I can give you the skinny. This is how we run the SDL in our boxster, we have the SDL tell our chasecam when to start/stop recording and the video is sync'd. Then we post-process using Dashware.
Dumb question from the cheap seats....
Its a sequential shifter obviously...so just pull to upshift...no fuss, no muss.
But for the downshifts are the clutch and throttle blips necessary...or just easier on the tranny? I thought the seq. tranny automatically blipped the throttle for downshift based on sensing the forward pressure on the shifter???
Or was someone pulling my leg so I would come on RL R&DE Forum and ask a stupid question......
That is by no means a dumb question! On this car, downshifts require clutch & blip. On some vehicles, the electronics do the clutch + blip for the driver.
Professional Racing and Driving Coach
If I remember correctly, there is an excellent article on the feeling/proper usage of using the shifter in the recent issue of Excellence where the author is driving the Lizard RSR.
My pleasure!
Apologies to the OP and others for responding to Mark. These posts have been deleted. I should have known better, sorry.
Mark, I think it is obvious to many drivers and most racers here why LFB could have been an effective competitive advantage for the video car, and where. I am sorry but I lack the interest in explaining it to you. No slight intended. The OP got it, that's what's most important IMO.
I would say that most racers do not left foot brake, but there are many that do. I wanted to see your opinon of the advantages, as I get a different answer from many high up in motorsports. Actually, I was talking about this with Pobst a while ago and he wrote an article about it. He had some interesting comments about the technique.
My pleasure!
Apologies to the OP and others for responding to Mark. These posts have been deleted. I should have known better, sorry.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
IMO a greater of a percentage of the good ones do than the percentage of the good ones who don't.
My opinion of the advantages, when situationally appropriate: quicker transitions from gas-brake-gas; much higher ability to use slight brake pressure, while on some measure of throttle, to subtly adjust attitude and/or rotation and/or balance of the car; much hig;er ability to do what I talked about in the Could I Have Saved It thread, namely to guide the center of the car's mass serenely with subtle adjustments to the front and rear of the car, sometimes simultaneously.
IMO, if one never uses LFB, one is leaving times & position on the table big-time. CAVEAT: some cars, such as those with e-Gas, make LFB more difficuult....but not impossible.
It might also help a high rear brake biased car in high speed corners where you would want less rear braking force, and the opposite for those that didnt.
certainly getting from brake to throttle faster is a small plus too.
