WTB 996 wheel stud conversion
Old 08-11-2009, 11:17 AM
flyingpenguin
flyingpenguin's Avatar
Default WTB 996 wheel stud conversion
I am looking to convert from lug bolts to studs on my 2000 996 C2.
AFAIK you need M14x1.5. What length should I go with?
JP
Old 08-11-2009, 11:58 AM
karlooz
karlooz's Avatar
JP
i use 14x1.5x65 by BBS
wheel studs
Old 08-11-2009, 12:13 PM
kgorman
kgorman's Avatar
+1, use red locktite
Old 08-11-2009, 01:02 PM
flyingpenguin
wheel studs
Thanks karlooz.
Now I guess that my WTB has turned into WHERE to buy. Any recommendations for online retailers that sell this stuff? I looked quite a bit without much success.
JP
Old 08-11-2009, 01:09 PM
Porsche917K
Porsche917K's Avatar
I bought my studs at Bildon. Use red Loctite and DO NOT follow the recommendation of torquing them to 150 lbs as you will read a few places on here.
Old 08-11-2009, 02:01 PM
986's Avatar
Thanks karlooz.
JP
I got mine from CDOC.
Old 08-11-2009, 02:45 PM
KOAN
KOAN's Avatar
I have a few sets of wheels, among them BBS and CCW. They require different length studs. Even the longest sold by Bildon BARELY fit the BBSs. The high temp red locktite is not enough alone to hold them without some torquing. If I really tighten them, the longest Bildon studs are not long enough. If I use the ones pictured above, the unthreaded portion does not allow me to tighten the CCWs.
Old 08-11-2009, 02:57 PM
bella1
bella1's Avatar
Default CDOC
JP
CDOC Dude! http://store.cdoc.com/contact_us.asp
Ask for Mark mark@cdoc.com
Old 08-11-2009, 02:58 PM
AllanJ
AllanJ's Avatar
Call up these folks:
http://www.apexcompetition.com/ProductInfo/
Old 08-11-2009, 03:01 PM
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
http://www.paragon-products.com/
In Texas as well
Old 08-11-2009, 03:03 PM
MUSSBERGER
uninformed gas bag
MUSSBERGER's Avatar
Originally Posted by AllanJ
"ACS 'Bullet Nose' Track Studs" Those look nice.
Old 08-11-2009, 03:19 PM
jbossolo
jbossolo's Avatar
So, what's the "correct" torque for these?
Old 08-11-2009, 03:28 PM
consolidated
consolidated's Avatar
I test fit the this stud to my SPBOX and Cayman with stock wheels and the unthreaded 10mm portion didn't allow the nut to fully seat without some doubt. The wheel thickness between the back and bottom of the spherical seat is about 10mm.
I re-ordered their "black track studs".
Old 08-11-2009, 08:37 PM
Porsche917K
Clean the threads good and use red loctite. If you do this properly you should only need to go hand tight with a ratchet. If you tighten too much, you'll just bury the shank of the stud in your hub.
Old 08-11-2009, 08:38 PM
karlooz
karlooz's Avatar
Thanks karlooz.
JP
click on the wheel stud link and it will take you to CDOC
Quick Reply: WTB 996 wheel stud conversion
