MOTON CLUBSPORTS?
So this is still not a 'slip your hand under there and adj' sort of setup? You still have to jack the car up?
What spring rates are you running D-Man?
Clockwise for soft, counter clockwise for stiffer.
Can anyone tell me which canister, large or small, goes in front and which in the rear?
You should have the taller one on the fronts, shorter rears but surely there are instructions with the kit?
I've found the dials on the canisters to be very sensitive and learned not to tune too drastically from test to test. Just a few turns is a lot.
Keep a notebook for your best setup at each track. I can never remember.
What sort of springs are you running and weight of car Firehawk?
How do these Moton's compare to similar types such has KW or JRZ's?? Especially in durability?
I recently purchased the Club Sports to replace the worn out Sachs on my Cup. Atlhough they are well put together, have good adjustability, easy to use, etc., I found the overall valving to be a bit on the weak side. In fact, I'm having them taken off and sent back to Moton for revalving. For the Cup at 9.5+/10, they just aren't strong enough out of the box.
Basic Site Sponsor
Basic Site Sponsor
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Well, outside of the cost being a lot more, I was told that the only difference was that there were more adjustments. and that the fronts had quick disconnects too (not just the rears like mine). I was told that the range wasn't any greater just that the adjustments were more incremental.... Hmmmmmm.
Basic Site Sponsor
Basic Site Sponsor
We actually found the Motorsport Motons to be too stiff for the setup we wanted to run on our BMW and we found there to be too much space between the clicks. We run a very lightly sprung car though...nearly 1/2 the rates some of you Porsche guys are running on your front suspensions and a few hundred pounds less than a lot of BMW guys. Ended up developing a set of Ohlins with the specific range of adjustment that we wanted.
Team Owner
FWIW, my M3 has 700f/800r springs, on a ~3,100 lb car with driver and fuel, and the Club Sports are superb.
Professional Racing and Driving Coach
Basic Site Sponsor
Basic Site Sponsor
Bryan, if you found too much space between the clicks on the Motorsport shocks and needed something finer, your **** must be really sensitive!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
BTW I have heard plenty of good things about Ohlins, and would consider them for the next racecar, whenever that happens.
Ha. For a given range of spring rates we know we plan to run, it just makes more sense to have the entire range of clicks on the dampers to operate within the same range rather than having 4-10 "clicks" of adjustment that aren't really usable at all. Or, in the case of the Motons, we only essentially had two clicks of the adjustment range that worked well at all, and no way to go softer for rain, etc. With custom valving, we were able to place our normal settings right in the center of the range. Noted, it definitely takes more work and it takes some math to come up with a starting point before you ever hit the track and start turning *****.
Larry, my understanding is that the club sport version has the same range as the motorsport version, just 1/2 the number of adjustments.
I concur on having the internal valving changed to work within the setup range your car is set to. I just went through this and it made a large difference in the ability to tune the car. Also, not all of the adjustments are linear, especially near the ends of adjustment.
