Safety Solutions Hybrid Pro vs. Hans
I am in the market to buy a head neck restraint system. A few people who I have talked to think highly of the Hybrid system becuase is provides better protection during off center impacts and second impacts if your belts get knocked off or come lose off the Hans.
Just looking for some opinions on the topic. I did do a search and found some discussion. Comments?
Safety Solutions Hybrid Pro - Head neck system
http://www.usracegear.com/product/SS-ProRa
The #1 job of a head and neck restraint is to keep your shoulder belts where they belong.
...and, most people do not realize that if you lose your belts your body and your head are decelerating at the same rate. Therefore, your head loads are zero and you do not need a head and neck restraint.
The spec was written around the HANS device, hence it is the only device used.
The spec is interesting to read.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Remember that the F1 driver is in a carbon tub with custom fit impact material for seating, formed and extended lateral head restraints, and belts which have very close moutning point. None of those exist in unison in any racecar run by most people on here.
what is not figured out? Is it the seats inability to contain the body's movement that lets the belts slip off?
Have you considered a DefNder?
here's a thread on it...https://rennlist.com/forums/racing-a...straint-2.html
The interaction between the belts and head loads is very interesting, and shows up in H&N restraint testing when the baseline is established, i.e. there is no H&N restraint (how weird is that, eh?). The original 50G tests at Wayne State use a LaJoie Seat with lateral support at the shoulders:
The 70G Delphi sled used for SFI & RSI testing has no shoulder support. As one might expect, the belts stay on the WSU dummy, but slide off the Delphi dummy. (There is only one test series showing the belts staying on the Delphi dummy, but that's another thread.)
With respect to the subject at hand, here's the interesting part: When no H&N restraint is used, the 50G sled at WSU generates higher head loads than the 70G sled at Delphi. Why? Because the belts stay on at WSU.
If you lose the belts you don't need a H&N restraint.
And you need less H&N if you are not wearing a helmet too. I think helmets and belts are here to stay and I want mine to work well together. What happens if the mid torso moves out of the seat but the upper portion does not? That is the belts stay put but the ribcage is unrestrained as it is with many seats in even a slight offset? Does the body deform in unwanted ways or does it just form the "C" shape?
