915 Transmission Oil & Change DIY Help
I'm going to change the oil in my 915 tranny for the first time.
What oil? Brand/Type/Weight.
Anyone have links to DIY articles or step by step instructions. Pix always help.
Tools/pumps needed?
TIA
Tools/pumps needed?
TIA
Swepco 201. A pump works best, you will need a gallon. First get the fill plug out of the side (because if you can't get it out you don't want to find out after you drain it). Drain the oil out the bottom plug, replace the plug, pump in fresh 201 until it comes back out the fill hole (car needs to be level). Put the fill plug in, your done.
thanks Gary. I thought you'd show up with the answer sooner or later.
I am going to change every fluid (If I could only find the radiator) and check everything. Not much droving these days so I might as well renew whatever looks like it has been a while since it was changed/checked.
Any suggestions?
Any suggestions?
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Any suggestions?
Any suggestions?
should i change the tranny plugs or reuse the old ones.
i have been on track once, early June, since VIR last fall. Had the car checked out and nut and bolted by J3. this time i'm going a little deeper than oil and brake fluid. Doing an August event at RA.
I remember how smooth my G50 tranny shifted after the oil was changed. New Swepco.
Just a consideration..... You may want to search the 911 forums for some opinions from Peter Zimmerman. He has a *ton* of history working on these boxes and his recommendation is NOT the Swepco solution.
Toby
Toby
Two more questions.
1) Does the trans have to be warm? My car has been on jack stands since yesterday and I don't want to take it down until I change the trams oil.
2) What is the torque spec for the drain and filler plugs?
TIA
TIA
