PCA Seatback Brace
PCA Seatback Brace
"All cars will be equipped with a seat back brace except as provided in Safety Rule 27 below. Said device will mount securely to the roll cage/bar and will rest firmly against the back of the seat. The portion that contacts the seat will
be a minimum of twelve (12) square inches and larger is suggested. The seat construction must be compatible with the seat back brace and not pose a hazard to the driver. The seat back brace for composite seats must have a minimum of thirty (30) square inches contacting the seat back, and must have 0.5” to 2” of high density foam padding between the brace and the seat back. The seat back brace cannot be bolted to a composite seat unless the manufacturer has designed the seat to bolt to a brace."
What constitutes a composite seat? Anything but an all aluminum seat or only those foam filled shells?
In this case, composite = non-metal
That said, does PCA allow you to run without any seat back brace at all as long as you have a current (i.e. less than 5 years old?) FIA approved composite seat?
I would say anything but an aluminum or steel seat, yet some composite seats are designed for a back brace. I would call somebody at PCA for tech and ask them if you need a back brace for a FIA approved seat; which most of your high end composite seats that are new are. If buying just ask first.
Most sanctioning bodies that feature more current cars have moved away from back braces with todays seat technology. Most historic racing still uses them.
Yes, but the mounts and rails must be FIA (not less than 5) too. Having an FIA seat is not in and of itself the only requirement. My seat mounts don't have a date on them, so I wasn't sure how I'd prove their age. Rather than fight the issue, I put a seat brace on my composite seat. It isn't too back stabby though, by design.
I understand the reason for having a date on the seat. The composite material can be effected by UV or wear, but what the heck on the metal brackets ?
What would be next, dates on the bolts used to bolt harness to the chassis?
The high density pad material is actually hard to find. Not that many people sell it. Also, seat back braces larger than 12 square inches are hard to find. All of the popular ones (like the IO port) are about 2" x 6". I actually can not see a commercially avaliable one that is large enough to qualify for the 30 square inches.
Also, no guidence as to the thickness or material of the brace ? Can it be alluminum ?
GT3 player par excellence
About 10 years ago at a Metro DE, Lime Rock Park, a 911 driver lost it in the rain on the front straight and backed it into the pit out retaining wall, not a huge impact, but the seat back broke and so did his neck as a result, against the roll bar, or harness bar, crossmember. Tragically, it was fatal.
Basic Site Sponsor
Basic Site Sponsor
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I was pretty sure it was a DE, although I was not there. Dreadful all the same. The guy was an acquaintance of a patient of mine, she told me he was heir to the John Deere fortune.
Frank, it was a club race, not a DE and there were a combination of issues with that accident. First, the seat was an older seat that, while legal for PCA, was not constructed very well and the driver was recommended to replace the seat. Second, the seat was moved by his mechanic to remove an ECU for PCA compliance checking and when repositioned, only 1 of the sliders locked in place. When he hit the wall, the unlocked slider slid and the seat broke from twisting.
