Track wheels & tires - transport in 968?
Old 05-09-2009 | 10:36 PM
mark kibort's Avatar
mark kibort
I'll put money on that it cant!
305s took at little change to my 10 year old pack up technique, vs the 275s and 305s. However, I found away to make it work
Thanks for the pic!
mk
Originally Posted by IcemanG17
MK
You stole my picture!!!! :>)
a 968 has quite a bit of room inside.....so I think it can be done....MK does it every race weekend!
Old 05-10-2009 | 10:52 AM
Dave in Chicago's Avatar
Dave in Chicago
Originally Posted by cooz
Dave S in Chicago has roof rack on 968 for 4 wheels/tires....
Hey there Norm. Yup, ye ol' roof rack...
Old 05-10-2009 | 11:16 AM
Riff's Avatar
Riff
Can you share the details of that roof rack?
Old 05-10-2009 | 11:31 AM
jpk's Avatar
jpk
I'm pretty sure it's just a standard Thule or Yakima rack system, they both have brackets for he 944/968. Once you have the main cross beams, the rest can be done with home depot stuff, just like what I did on the tounge of my trailer; 1 1/2" threaded pipe floor flange and a short piece of pipe to thread into it. Figgure out some way to bolt the flange to the cross bars (U bolts or such) and you're golden.
Old 05-10-2009 | 11:52 AM
Dave in Chicago
As John mentioned, it's a jig I scoped and assembled that just centers 4 wheels/tires while affixing to the crossbars of the stock Porsche 944/968 roof rack (ever wonder what those little bolt holes under the hatch are for?). Factory roof rack came in a BIG Porsche box.
Pretty sure I'm the only knucklehead driving a car to races and back. Now, where did we leave that transporter???
Old 05-10-2009 | 11:53 AM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Originally Posted by N_Halbert
The other is a rear hitch carrier or tire tail
Very bad idea.
I am fairly certain that configuration will exceed the tongue weight spec for that hitch/receiver.
A failure waiting to happen.
Old 05-10-2009 | 12:24 PM
DanR's Avatar
DanR
Originally Posted by ltc
Very bad idea.
max tongue weight is 200 lbs so that must be right about the max
Old 05-11-2009 | 06:44 PM
mark kibort
Just sitting there parked, it should be just fine! Just dont hit ANY bumps!
Old 05-11-2009 | 11:00 PM
Sysgen's Avatar
Sysgen
Wow, this is great, it made me realise that I have a similar rack I used on my daily driver and tonight I checked if it fit on the 944 and it does
Do you think this trim piece is sturdy enough though?
Could you tell me also what you used to wheels from moving around?
Old 05-12-2009 | 12:45 PM
RJFabCab's Avatar
RJFabCab
Originally Posted by mark kibort
No one can beat this I dont think!
All (4) 305x18s in the 928. Along with cooler, tent, tool box, spare parts, (2) 5 gal gas cans, jack, scooter, overnight gear, racing gear, etc.
7 full racing seasons, no DNF's, most always driven to and from the track. Sometimes with a wingman too. (That's scotty in his 5 liter old bugger)
mk
Wow. One word came to mind...
JENGA!!!
Old 05-12-2009 | 12:47 PM
RJFabCab's Avatar
RJFabCab
Very bad idea.
The wing gives him a 22 lb buffer
Old 05-12-2009 | 01:48 PM
ValveFloat's Avatar
ValveFloat
I haul my rear wheels on a Yakima rack on my 911. I built a couple T-shaped bars that tie the front and rear Yakima bars together with the leg of the T sticking up thru the center of the wheel. I run a strap around each tire and the rack in an x-fashion and ratchet it tight, works really well. There is a not that great picture of it here. The T-bars are attached to the Yakima bars with U-bolts. the T thing sticking up is really just for piece of mind the straps hold the tires really well, and having the front and rear bars tied together makes the rack very rigid.
In the image, the round bars are the Yakima bars, running across the car.
Old 05-12-2009 | 04:46 PM
mark kibort
I didnt see the rope wrapped around the wing for support though.
Old 05-12-2009 | 04:59 PM
M758's Avatar
M758
here is another option.
This guy drove 700 miles one way like this. Won vs 25 other 944 spec cars and drove home.
