OMP and Racetech seats- how do they compare?
#46
Excellent info here. I recently bought a car with an older, wide, non-halo seat, that I planned replace later. For now, I made a nice fiberglass lined foam insert & welded it to an OEM slider.
However, trying to get a NASA logbook, I learned that because the seat's >5 yrs old, a seat back brace is required. NASA also requires a center net for non-halo seats. Those 2 items add up to $200 that I could apply to a new seat.
After shopping around online, the OMP RS-PT seems like the best bang for the buck, especially with the free shipping offerred by Discovery and Apex.
I just noticed some shops advertising an OMP RS-PT2, still at $699. Anyone know anything about this???
#48
RS P.T.2
The new RS-P.T. 2 is the latest model from OMP. It meets the latest FIA seat specs. We are in the process of updating our site to reflect this seat but if you order the RS-P.T. regular, you'll end up with the RS-P.T. 2. It's the same price with a better FIA spec.
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
#49
I once had OMP Grip and OMP RS, which were quite comfortable. I just bought a Racetech RT4009HRV. It is much stronger, in torsion at least, than the OMP. I was imoressed byt the quality of the products. But I don't have anything bad to say about the OMP seats.
***I don't want to hijack the thread - but if you could help, it would be appreciated***
My problem is to fit the seat in the car (944) ... I'm using the recaro sliders. The seat cushion does not allow the use of the handle the sliders (the bar that connects both rails).
I could bolt it right in the floor, but I would prefer to keep the sliders, for ease of exit...
Any other solution thant those Recaro sliders?
Charles
Charles
#50
#51
Also bear in mind anyone wanting to use a Halo seat in a car that gets street driven is in for a rude shock from my observations. I actually returned an OMP Halo for this reason. Reverse Parking or reversing in general is a nightmare, as is changing lanes in busy fast moving traffic. Be very wary of buying these based on looks alone. This is one Race Bling you want to avoid on the road.
#52
This is all a lot of great info. A couple of us have been looking at a number of options. Finding the right size seems to be the most important aspect if the seats are created somewhat equal. The three of us range in weight from 150-170, from 5'9" to 5'11", waists from 32-34. Here is what we have found so far:
1. Recaro Pro Racer HANS - Too tight and too expensive
2. Sparco ProADV -- Too wide (cavernous)
We are wanting to try out a Sparco Circuit and an OMP HTE seat. Does anyone know how these might compare size-wise vs. the OMP RS-P.T.2 or the RaceTech? I'm looking at dimensions online, and it is rather difficult to compare as it doesn't seem there is a standard in where they are measured.
#54
Hi Paul:
Sounds like we share the same measurements. I am 6'0" 175 and the Racetech RT4009HR fits me very well. Drove a car with this seat in it and this will be the seat I put in my 911 when I replace the current MOMO seat I have had for years. Definately try to sit in one at the track. I think you will like it.
#55
Hi Paul:
#56
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
#58
FWIW I have the OMP RS PT and it fits very well except the shoulder harness cut-outs are a little low and pressure my shoulders. Try before you buy. I did but without helmet and HANS.
#59
i did not read entire thread. did someone mention fia tests are at 20 g's racetech tests seats to 40g's iirc. Also, mounting seats properly ismoreimportant than what see is bought. RT has back brace section molded into the set which provided 2 factory mount points. I have not seen omps with that but i have not looked in a while. this factory brace section is very important especially after the 5 yr point. plastic seats should not be drilled and back braces resting freely on seats have issues.
#60
