View Poll Results: TPMS Sensors for Track Wheels?
Yes.
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
8
57.14%
No.
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
6
42.86%
Voters: 14. You may not vote on this poll
Moderator
I've done it both ways. Ran without TPMS and got error codes and obviously no information. Ran with TPMS and got error message, but also got readings. While not accurate, they at least show the relative pressures and will also show a pressure loss. I've had no issues with my Porsches, but on a previous E46 M3 I had a valve stem hit by debris, causing me to lose pressure within half a lap (limped back without incident).
So, when my 09 arrives that will make the 06-08 TPMS sensors obsolete and I'm considering getting a set of 09s to put on the Volks when it's time for new R888s.
I don't see any downside to the sensors other than perhaps weight inside the wheel. Thoughts?
Just put them on last week, for this weekends DE at Road Atlanta. A total positive for me. No annoying warnings and peace of mind on pressure changes. I'm pleased with them.
Just bought a new system for the race car..screw on valve sensors to report to a in car system. Next outing WG on the 11th. I will report on them then...but I cannot see any down side. To me it is better than getting someone to take to PSI as soon as I come into the pits ( they say you lose 1-2psi on cool down), or jumping out with gauge in hand and takling reading myself!
Checked this system reading with the most accurate gauge I had and it is dead accurate. Finally I will be able to see what those Hoosier's are actually doing.
Still plays with cars.
Bought 18 inch wheels and the sensors. Got tired of the beep and warnings. Had a falt in the last race of last season. Had I seen it coming .. i.e slow leak, I might have finished.
I am getting sensors for my track wheels next time I swap out tires.
Ron, the TPMS for the new 09 seems to be a lot better than the previous version. No issues and a lot more accruate.
Former Vendor
Jim
The system I purchased is called Opti-grip, it is from Hot Lap MotorSports,Inc.
www.opti-grip.com
I have experience with the screw on valve stem preasure monitors from my RV system.
This particular system seems VERY accurate down to th 1/10 psi digit(ex.33.2 PSI).
I don't know if the extra weight is going to throw off the balance of the prebalanced wheel..about 1/3 ounce..put if it is sucessful on track I will balance them with the sensors screwed in to the valves.
Easy to change to one of my other 3 sets of wheels...I'm hoping it works.
www.opti-grip.com
Jim
www.opti-grip.com
www.opti-grip.com
Have TPMS on my track wheels and find them very helpful to monitor relative hot/cold pressures and to safeguard against major pressure loss while on track.
Only problem is that cold pressures are much lower than built in tolerance in TPMS computer which gives low pressure warnings but that is easily cleared.
