ABS Hard on Brakes?
John, what you are hearing is that the brakes, particularly the rear, are abused on cars with stability management and traction control because the computer uses the ABS control unit to assist with wheel spin. It is not uncommon to see a heavy 997 street car wear out its rear brakes prematurely because the computer is using them under acceleration to keep the car straight and wheels not spinning.
Thanks Geoffrey. The reason I asked is because VR stated in a recent post entitled "ABS vs No ABS:"
"All that said, my M3 started as a street car, and I try my best not to get into ABS at all, because it beats the **** out of the brakes. Hell, SRF's dont even have ABS!"
I was just wondering the basis for this statement.
What about it VR?
What about it VR?
What he said... presence of ABS doesn't impact how often or how hard the brakes are applied - that's up to the driver. Only thing there that the ABS can do is (try to) keep the brake/tire operating at max efficiency. It's the TCS and ESC (what you know as PSM) that'll activate the brakes more... in particular, oversteer interventions hitting on the front brakes to wear them, as well as TCS on the rear axle as appropriate...
What about it VR?
What about it VR?
In my experience, drivers who regularly and heavily engage ABS (irrespective of vehicle) on track experience much higher wear rates of brake components, as well as much higher probabilities of fluid boil, than drivers who don't. Same type of vehicle, same pace, etc.
Professional Racing and Driving Coach
It seems intuitively that the plusating ABS would introduce higher heat and forces on the rotors, that normally for near the same overall braking forces with threshold braking, would not. Modulating near 1000hp at rapid fire frequencies, might just shake something lose, in time .
I think what VR is saying has merit. One of the first ways a driver gets faster is to brake later. (early throttle on exit would be a better start). This translates into excessive late braking and slow corner entry. Instead of slowing from 130 to say 70mph they keep on the binders to 50mph (instead of releasing). I have noticed that the new GT3 uses rear brake pads at faster rate than the fronts (surprising to me) so Geoffrey's description of the brake system make sense.
Are you running it with any TCS or PSM active? If so, yes... or have you done anything else to change the car from stock - suspension balance, brake bias, pad material, etc? Any of those can also impact wear rates...
Geoffrey, could this also be the reason or at least a contributing factor to why I am seeing accelerated rear pad wear on my 89 964 C4???
