Hans device preferance Q
I am thinking about pulling the trigger on a Hans, and I thought what I wanted was the the sliding tether with the NEW quick release system.
http://www.apexperformance.net/CartGenie/prod-1703.htm
then someone posted that they did not really like the quick release system that it was not all that much better then the standard connection.
option are sliding tether standard connection
sliding tether quick click release.
For those who have a Hans now if you were in the market today what way would you go as far as connectors or release systems go.
I have a HANS without the sliding tether but with the quick release system. I don't think I've ever used the quick release system, and in fact, I always get nervous when I put my harnesses on that I haven't accidentally disconnected my tethers by having the quick release ribbons caught in something. I always put my helmet on at the same time as my HANS, and have them connected almost all the time, so I really don't need the quick release system - if I had to do it all over again, I definitely wouldn't get them.
Frank - I have a Hans with sliding tethers and the standard connection and find it quite convenient. Matter of fact my Hans is more or less "permanently" connected to my helmet That's how I store it (connected) in my Hans carrying bag and I don and take them off as one unit. So didn't find the need for a quick release. Others may have differing preferences.
I just upgraded to the quick release sliding tether. I like it so far but, I haven’t tried in a race yet. I like the sliding tether but being able to put the helmet on in the car helps with taking the helmet off on the grid between a long grid wait.
Needs to Get a Life
Same experience.
Thanks guys that is the word I am getting that the sliding tether is the ticket but the quick release is not that much of an improvement. that the standard connection is not all that difficult to get off. I guess the issue is if the car is on fire does the Quick disconnect get you out quicker but maybe its not that much of a factor. I like simple thinking of the sliding tether and standard connection.
+2
Sliding tether is great.
The standard one makes it impossible to have the car in reverse in the pits and see what it behind you. You just can't twist your head much to the side.
The sliding tether is a major improvement.
Moderator
Joe Marko from HMS gave a long safety discussion last year at one of our PCA events. His feeling was that while Hans is selling the sliding tether option, he felt it was not as safe as the fixed. The reason being that if you can slide your head around more to look left and right while driving in the pits (vs. using mirrors and eyeballs), then that means in an accident your head will move more as well, somewhat negating the whole purpose of having a Hans. Based on his advice, I went with what everyone had used in the past, what the pros appear to use, etc. -- regular release and no sliders. As with most, my helmet and Hans are used as a single entity - the works goes on and comes off. I never disconnect as there's no reason to.
Frank,
I had the quick releases, and used it often when I was getting in and out of students cars who did not have harnesses. I switched to the sliders, and like it much more. If you want to try the disconnects, I'd be happy to send them to you and you can use them and see what you think.
Frank,
Unless your car requires major head contortions to egress, there's no great advantage to the quick disconnects. Sliding tethers are useful in the paddock but this isn't a huge issue in 10 mph traffic.
The sliders true safety utility is if you ever happen to spin off track. With the old non-sliders, you often can't turn your head enough to look over your shoulder to see if oncoming traffic is coming. It is very reassuring to know that you are not about to be collected. Reentering the racing surface with non sliding tethers occasionally requires a leap of faith that noone is going to hit you.
The second big advantage for me of the sliding tethers is being able to turn my head enough to look all the way through carousels and hairpins to see my trackout point early. The sooner I'm looking at the track out point, the quicker I'm back on the power. Others with more skill and courage than I may not have this issue.
For me, the theoretical disadvantage that my head might twist more in a wreck is far outweighed by the above issues.
Frank,
I'll bring them to NOR Mid Ohio. I agree with PRG about looking ahead. It seems easier ( for me) to disconnect the tethers with the quick release hardware than with the helmet attachments. However, I prefer the sliders and just keep the HANS on when I go to non-harness student's cars. No big deal.
