Engine shelf life
If I want to build an engine and have it waiting in the wings in case something happens to my main horse, how long can it sit there before it needs attention again? Will the seals start to go bad if it just sits in one position? Do I have to worry about corrosion on the inside?
What about oiling of the engine? Should the engine be run once with oil and then stowed away, or just leave the assembly lube in there?
At the very least I would assume you'd want to plug up any openings to keep creatures from making the engine its home.
Basic Site Sponsor
Basic Site Sponsor
Interesting question. I had a spare motor that was just sitting for about 3 years. 2 of the valves wouldn't seat when we tried to do a cold leakdown (I know, I know - should only do one hot). The other 4 were under 3%. The motor was perfect when it was removed. I installed it and it was run for a few hundred miles, and after a hot leakdown all cylinders were 2% or less. Some rust/crud/carbon must have gotten onto 2 valve seats.
In retrospect, I would spray lube into the cylinders, and rotate the engine a few turns every 4~6 months. Make sure to leave it in a different position. You could also not tighten down the valves. I can't imagine that any seals would be negatively affected by not running. Also, I probably would not initially run it, because of all of the moisture that would be produced and then left to dry out while it sat.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
RL Technical Advisor
Hi,
Properly prepared, one can store an engine for a long time and that especially holds true for ones that are not ferrous,...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Seals won't last forever so be mindful of what you use when you build the engine as they are NOT all the same quality.
Rotate it every 6 months and you'll be OK.
Herr Unmöglich
I plan to rebuild the motor I just pulled from the racer in my off time over the next year or so. I don't know that I want to swap motors every year... maybe every couple at most.
Geoffrey, any chance you could share what those lubes are? Right now I use Redline on the moving parts... for long term is something else better?
If the engine sits, you want to use a thicker assembly lube rather than the standard red thick oily assembly lube you might use on a standard engine build. Redline works well...
+1 on the redline....Keeping moisture (and critters) out is the key, if you're in a hot dry climate not too much to worry about, but if you have moisture it can cause problems. A light coat of rust on a valve stem, piston ring, cam, or follower can lead to premature guide or lobe wear, biggest pita is a stuck ring. If I'm doing a project where it's going to sit I coat the internals with Aeroshell 2f, then use plenty of assembly lube, particularly sure to coat the seals completely to keep them from drying out. Plug up all the openings with a dessicant strip with a plastic or foil over the top and you're good to go. If its crated or just put away after assembly it's pretty easy, a bigger issue is if you dyno the motor and then crate it, then you have moisture and other fluids to consider...
Basic Site Sponsor
Basic Site Sponsor
You should have no problem if you prep it properly and keep it dry...that said if you were thinking about keeping it that long I would build up the shortblock and assemble the head and then put it in storage as major components. It stores easier, if you need to replace a head or steal a part for another motor your not cracking a full build. Mostly though things change....you decide to upgrade cams, pistons, run a different class etc...rather have it in bits than tear it down to build it again...(been there done that...)
