Braking Bias effects on a Road Race Car
#46
Basic Site Sponsor
Basic Site Sponsor
The 100 marker, on the back straight? C'mon Dave, tell it to the newbies. Unless your car was only going 110 mph, there is no way you were able to brake that late.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#47
#48
That rate of decel is mind boggling! How heavy is it, exactly? What size are the front tires?
#49
I'm in....
Is that necessarily a constant bias % though? Not all braking zone / corners are created equal. Do you guys with adjustable bias change at all going from a long, high speed course to a short tight one or visa versa?
#50
At the time that data was logged, it weighed about 2360 lbs. Add to that some fuel and a 240 lb driver.
Front tires are Yokohama 250/650 18 soft compound.
I don't think it is fair to compare this against a 997 Cup. The racing ABS that my car has allows the driver to get the max out of the brakes with almost no risk.
Chris Cervelli
Spline Technologies
#51
Chris,
Why kind of average decel do you get in a straight braking zone. Peak accel is cool for bragging rights but doesn't show the entire picture, especially for a non aero car. If your peak shows 1.8, but can only sustain an average of 1.4 and my peak shows 1.7 but can keep my average at 1.5 then I can out brake you every time. What type of accels are you running? I've found that the mid-low range accels are suseptible to more noise than the high end ones.
As a note, I have seen average decel of over 2g for a non aero car, but it was a very small open wheel car.
#52
Its not exactly at constant percentage but awfully close. If you've tuned the bias for brake lock on all four wheels at the same master cylinder pressure (which will provide maximum braking) then any changes away from that would most likely be solely due to driver preference.
Our Daytona data showed that Ross was driving our Cup Car with a 3.7% bias setting, to the rear. I'm almost thinking that it might have been due to the much stiffer than normal rear springs we were running, as well as driver preference.
#53
Ultimately, it sounds like we need to go into 10A side by side and see how big the difference is.
#54
Why would down hill add to your "recorded Gs"? It should reduce it actually.
Downhill would add to the "recorded" G's of the accelerometer, but should actually decrease your braking ability, right? I wonder just how much the downhill is playing into the readings, because 1.99 seems really high comparatively. Even 1.65 sounds really high for what I would expect. I would expect numbers more around 1.2-1.3 like the 997 Cup car data from this year's Daytona 24 posted on the first page of this thread. What data acq system are you running? That's scary good braking for a tin top.
I don't have any data saved on my work laptop...makes me anxious to see what sort of braking G's we're hitting at 10A as compared to flatter braking zones at other tracks.
For what it's worth, the left side of the track at T10 is even grippier and less bumpy than the right. But you can really only use it in the wet because it blows your 10A entry in the dry. I love the 10A/B complex for some reason...one of my favorite turns on any track when I'm going through there well.
#55
With a driver, our cars are at similar weights and we run the same size front tire. I suspect you run wider rears (we run 280's) and obviously you have more weight on the rear. Your braking numbers just sound really high. Then again, comparing G's between different data acq systems in different cars may be as fruitless as comparing dyno numbers between different dynos...I don't know enough about them to be sure. Perhaps they are good for comparing relative to themselves, but not for comparing to others.
Ultimately, it sounds like we need to go into 10A side by side and see how big the difference is.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I also run a 280/680 18 rear tire. What lap times are you running? This lap was 1:27.3. I mention that because comparisons between cars that are more than 3 seconds apart are usually misleading.
The G sensors should be reasonably close if both sensors are calibrated right (which is a big assumption).
My car cannot do 2 G under braking consistently. It appears to have hit that number in this brake zone on this lap on that day. I would expect any reasonably optimized 2400 lb race car on slicks to hit 1.4-1.5 almost every time. I am assuming a decent ABS system.
I think in this case I am getting a little help from the 155mph approach speed and the good pavement conditions at this corner. As I mentioned the downhill orientation is going to add a little negative G to the reading as well.
Chris Cervelli
Spline Technologies
#56
Our cars sound fairly comparable...would probably be an interesting data overlay to see where each car is stronger. Would be nice to race with a well driven and setup Porsche. Seems like all of the Porsches that run "similar" speeds as us in NASA or PBOC are much faster cars (700+ hp modified Cup cars or GTS RSR's) being driven rather poorly, so I spend all of my time being held up in the corners and losing 10-15+ car lengths on the straights.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
We could definitely benefit from ABS. It's the next improvement on the list.
#57
A little thing called gravity comes into play. For that matter, body roll, brake dive, and acceleration squat prevent you from getting a totally accurate G reading from most of the data acq. systems, again making numbers between cars hard to compare.
#58
I would think since you are going down hill, the road is falling away from you, reducing grip and subtracting from the cars ability to stop. If you are positive that downhill adds to the g-meter's output, Ill have to think about that, or read up on it as to why. sure, roll, dive and things that upset the orientation will change the output I imagine.
I havent played with any of the high tech gymos yet. just video, track markers and stopwatches.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
mk
mk
#59
But it should be "add negative" as mentioned above.
#60
No one is arguing that, all other things being equal, a car won't take more time to stop in a downhill braking zone than it will to stop in a flat braking zone. That's a given. That will obviously lower the rate of deceleration. But, because the car is pointing downhill (and experiencing dive), your accelerometer is going to read a higher rate of deceleration than the car is actually experiencing.
