At what point do you replace your rotors?
Old 02-27-2009, 10:33 PM
007DT
007DT's Avatar
Default At what point do you replace your rotors?
My current set up is OEM Rotors, Hawk DTC Pads. Prior to using this pad compound I was changing rotors and pads 1 to 1. I'm now on my second set of pads with this same rotor and all feels fine. Being that the OEM rotor have cast holes, I've always been told that the fine cracks are OK so long as they do not run to the edge and/or they are not connected. So my question is; How do you know when to replace your rotors?
Old 02-27-2009, 10:36 PM
jrotsaert
jrotsaert's Avatar
You've answered your own question. Holes connected and going through the edges... You need new ones clearly
Old 02-27-2009, 10:39 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,418 Likes on 759 Posts
Dave, I strongly advise you go with slotted, not drilled, rotors for serious track use. Also become familiar with the minimum recommended thickness printed on the rim of each rotor, and borrow or buy a gizmo to measure rotor thickness.
Professional Racing and Driving Coaching
Old 02-27-2009, 10:47 PM
Geoffrey
Geoffrey's Avatar
Wrightwood racing has a nice kit for your car that uses 332x32 slotted rotors and comes with a spacer and longer bolts for your existing caliper. These are slotted AP Racing or slotted Alcon rotors and they last a long time. I'm going on 2 years on my fronts.
Old 02-27-2009, 10:51 PM
Veloce Raptor
Yup, I use 332x32 StopTech slutted rotors & calipers on the front of my car (stock rears), with PFC01's all around. Front rotors last ~1.5-2 years, rears about the same. And you know how I drive, Dave.
Old 02-27-2009, 11:03 PM
007DT
007DT's Avatar
Thanks.. Couldn't find a website for Wrightwood. But I've looked for slotted that would fit my set-up without going to big reds and everything was $$ Custom.
Looks like I'll throw another set of OEM's on as I have a track day next Friday.
DaveM993
DaveM993's Avatar
those rotors are nasty...
(I thought I was pushing it...that's a 'hole' new definition)
Old 02-27-2009, 11:07 PM
007DT
007DT's Avatar
I figured I could pull the e-brake and Drift through the corners
I had planned on replacing them before RA. As mentioned above I have a set here already.
Old 02-27-2009, 11:13 PM
Geoffrey
Geoffrey's Avatar
I'd make a joke here, but I don't have nearly the practice you have...
Old 02-27-2009, 11:17 PM
Veloce Raptor
Old 02-27-2009, 11:25 PM
Mark in Baltimore
Mark in Baltimore's Avatar
I am offended by this statement. This is a technical forum; please refrain from salacious descriptions.
I have tracked rotors that were worse than this one, but, of course, it depends on how you brake or, to be specific, how little you brake.
Old 02-27-2009, 11:27 PM
todinlaw
todinlaw's Avatar
I think the conventional wisdom is replace when 3 holes connect or if the cracks reach the edge of the disk, Also, I saw a tech sheet that said that if the cracks are more than 7mm long. my rotor cracks are longer and deeper but not as many. Better safe than sorry on the brake hardware, I always say.
Old 02-28-2009, 12:01 AM
bobt993
bobt993's Avatar
I am with Mark on this one. I likely would run another day or two on those or at least a race and a practice session. Keep them for spares if your going to replace them.
Old 02-28-2009, 12:34 AM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Wait till you hear that thumpa-thumpa noise!
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 02-28-2009, 12:45 AM
Ed Eubanks
Ed Eubanks's Avatar
Dave:
Good advice about the spiderweb cracks from other folks. Replace 'em.
For the front, after about 18 -20 DE days last year (VIR, RRR, & CMP) I've replaced OEM rotors twice and PFC 97s twice too. Rear rotors and pads once.
By the way I'd really like to know how to get in touch with Wrightwood. I'm guessing those are custom hats and floating rotors.
Ed
Quick Reply: At what point do you replace your rotors?
