A company that can convert my foam tip ear piece transducers to custom ear pieces?
#32
I have made some good progress on this today as I ended up with a few hours to tinker with making a cable. The schematics that Chatterbox sent us took a while to read but I got the system to work with our standard NASCAR helmet kit and earbuds but it did require change up to a higher output mic on the non-chatterbox side. It is not yet perfect, I am chasing a hum but otherwise it is close, next I with test with the IMSA plug as I know some of you are using them as well. An other option I am kicking around is one that would let you use your Chatterbox mic with your aftermarket molded earbuds.
#34
Chris- I am very interested in your solution. The Chatterbox earpiece converted to a flush mounted earbud is the goal. The mic (in my case with closed helmet) could be detached from the mic boom and just placed with a piece of velcro (or hard mounted permanently) to front of the helmet.
#35
#38
Did you ever toy with this approach? I received my custom molded earbuds and now I'm thinking of cutting the wire running to the chatterbox earpieces and wiring in a female end for the custom buds. Any advise?
#39
Yes, we are just finishing an adaptor for this, it will allow you to use aftermarket earbuds with the chatterbox headset mic, and it is a plug in which your original adapter is unchanged. It will be around $50 and we should have a run of 10 of them done by the end of next week. The NASCAR helmet kit - Chatterbox adaptor is still a few weeks away.
#40
#43
You provide the sticker, I'll provide the wing (as long as this is standalone and does not need the wiring harness to work--I have that in the Miata but not the GT3). If you give me a couple of other stickers I'll photograph them on the Ring car next month.
#45
Hi David,
Well, it turns out to not be as easy as i first thought, the power needs of the pro helmet system mic and earpieces asks a lot of the small chatterbox's battery, and I have a hum that I have yet to sort out. We have been moving our office during the past month and this has been sitting in a box right now.
