How low can you go with a 993
Just like the title says, How low can you go?
I have assumed once the lower control arms go past horizontal you start seriously changing the dynamics. So without some serious suspension modification, RS or slightly lower is the limit. Anyone have any additional perspective they could share? The car runs PCA stock so moving pickup points etc is out of the question.
Jeff
Jeff
Btw: I love the pic of your car in your sig, the RUF wheel look great on a turbo... It looks like you have a little additional rake in the car... intentional?
Technically EVO uprights are out too... With stock uprights bump steer is definitely a PITA, but manageable at RS height. I think I read somewhere that the roll center is also negatively affected.
w/ EVO uprights and ERP ends you can go very low, another 1" lower than RS. The Cups did that w/o the adjustable ends
With the stock 993 setup you need to run to maintain class elidgability, the rear will be your issue as it toes out. You need to set the rear, using the kinematic toe to reduce the rear bump, then set your front so the car has 1 to 1.5 degrees of rake and that will be your ride height.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
.....With the stock 993 setup you need to run to maintain class elidgability, the rear will be your issue as it toes out. You need to set the rear, using the kinematic toe to reduce the rear bump, then set your front so the car has 1 to 1.5 degrees of rake and that will be your ride height.
Any advantage to running minimum k/t w/ harder bushes?
You can certainly go too low. I worked on a friends 993 that fell into that catagory. Wound up raising the front (and back) about 20 mm and the handling came back. It is easy and tempting to go too low, and it messes up the geometry, which ruins the handling. My old RSA was about as low as you could go, and it needed cup car stiff springs (read more than 1200 lbs) to compensate for the ultra-low front roll center.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I'm kinda in the too low category (below RS) on my 993. One thing I've discovered is that changing the rake to nearly zero helps when its this low. Using extra stiff springs also helps to minimize the bumpsteer up front (since you need travel for bump steer) like Larry mentions.
I'm trying an ultra low setup right now (or shortly, it's still in the shop). Part of the issue is that the Motons I have are fairly short and I want to be in the sweat spot of travel. To get to RS height, I'm almost at the top of the shock travel. At least, that's my theory. Hey, if it doesn't work, I'll raise it back up to RS height.
G.
G.
Jeff
Jeff
I had mine (silver) about as low as you can go...
