Jim McNemar had this same issue at Mid-Ohio a couple years ago... It's not "un"common.
Mike
Originally Posted by Blondurant
Sorry, DEs. I know it's taboo to call it racing but it sure feels like it. Especially when you're in the top run group and get to pass in the corners. I digress... Hopefully will club race in the future but most likely won't be with the Cups.
the pulley problem is more common in GT3's with a lwfw mod, which I believe yours has...hopefully, your mechanic used loctite when he replaced the pulley bolt...have him check it before each event and you should be fine...as far as rms...if that car hasn't had a history by now it is not likely...the diff is another matter and requires inspection regulalrly as do wheels, tires, rotors and pads...I'm pretty sure Dell switched out the droplinks for the sway bars...the stock ones like to work loose...they should be checked regularly also...the more events you drive the more often you replace fluids....other than that...drive the heck out of it and enjoy!
the drop links, the clutch, the flywheel, the gearbox, the diff, the.....................
How are you an instructor? I remember you running in Blue at ECR just a few months back?
The last ECR event (Club race), I ran yellow. I may have started in Blue though, I can't remember! I'm in yellow with PCA but ran in white a few sessions last weekend. I run with the instructors in red with TDE. I'm an "instructor-in-training". Will start going out with students in a few months.
