First race from Lightning
I just love this track. We ran a one hour enduro, had 35 cars on track and it was cut and thrust the whole time. First of all, I think this track is very safe. In most places you can see well ahead, and more importantly; there's absolutely nothing to hit anywhere (except each other). A number of cars went off, but the result was only big dust clouds, nobody hit anything. Secondly, there are many passing opportunities, the speeds are high enough, some corners like the light bulb have multple lines and we could even corner that thing side by side. Third, it's not hard on brakes, it's a fantastic rhythm track, no question it puts a premium on handling although the front straight is pleny fast as you're on the gas hard for a long time. Lastly, the pavement is just dreamy, smoothest anywhere. Funny thing, though; as there was no rubber or visual groove yet, it takes awhile to figure the place out.
I love this track, and perhaps best of all; we haven't even seen Thunderbolt yet!
thanks for the update...
Further, not only is there vast runoff, but all off track is graded and flat with grass. I'm sure you could drive off at high speed and still collect it, I think it would be really hard to flip a car here.
As a result, you'll feel confident pushing your car farther here, no need to leave margin for "blue bushes" and the like. This is not to suggest that it will promote recklessness, you still need to be technical to go fast.
Where are the best places you found to pass?
How was T1 on the start? Were cars able to get through 2 or three abreast?
What was T5 (blind right hander) like with traffic?
1- lots, see video coming very shortly
2- it's a good set up, 2 wide ok, but not as fast that way
3- it's a great spot, you can duck inside at entrance or either side after apex. There's a trick to this corner.
As you'll also see, light bulb is banked nicely and two wide all the way around works.
BRB, I'm working the vid right now
