Are Pagid yellows overkill for DE's ?
Since Pagid yellows are endurance pads used on full race cars during races like LeMans and Sebring, are they overkill for weekend DE's where the longest session is probably 30 minutes? Would there even be enough heat generated to use the yellows to full advantage? Or would the short sessions just add to the pads longevity and still be in the proper heat range? Do you feel there is a better choice? If yes, what and why?
Still plays with cars.
Pagid Rs 19 or 29 yellow are ideal for DE. Stock pads do not stand up to the heat of repeated braking by a good driver. They are also fine on the street unless you drive in temps less than 40 degrees. They last a lot longer on the track than oem pads and are rotor friendly. What's not to like?
GT3 player par excellence
if you are in hi intermediate or advance, oem pads will not stop you very well and they wear out very very fast. i got to the backing in 200 miles of track use. (granted it's a very brake heavy track). when i say "backing" i mean it. i have zero pad material left.
I had also followed Mr. Rouleau's advice on my RSA but will try RS29 and 19 for the 996..... According to Chris R., it seems to work beautifully on his CS (same calipers Fr and Rr as my 996).
depending on your level of driving .... but once you begin intermediate level you should be running more of a performance pads, however changing pads to higher temp pad you should/ ( my opinion Must) change brake fluid... i would recomend Motul or i happen to use SRF.. but higher temp of pads and rotors will I promise cook your stock fluid.
I ran pagid yellows front black rear and never had a problem with braking on any corner on any track, i wouldnt change them if i drove on the street they can make a hell of of a noise but WTF the exhaust note, roll bar and harnesses would tell folks its not a typ. street car
the yellow black combo just helped balance the braking and gave the rear a lil more bite
I run yellows front and back for the track. Some run yellow front and black rear but that only works better for the more front biased 996 cars. The yellows work just fine on the street but are very noisy so I just swap out pads when swaping wheels for the track. Changing pads is fast than changing wheels.
*Quick flag about the stock pads and novices.
Most novice/intermediate drivers I've seen, brakes inconsistently and drags the brakes. They actually wear down the brakes quicker and tear the softer compounds (like stock) quicker.
Regarding fluid, used mostly SRF and Motul - both worked like a charm
Pinecone Watchman
The vibration dampeners do not work with the Pagid Yellows (RS29) because the pads are thick. I do not use them at all. I reinstall them with the stock pads by taking off the sticky backing so they slide in and out with the stock pads.
