Infineon Raceway questions
There is no curbing at turn 11, just some paint on the pavement. When we run there are stacks of tires to keep you in the corner, as long as you don't hit them, you are fine (I didn't watch the NASCAR race so I can't comment on what they did).
Ah, that makes sense as well. I was talking about that one turn where they track out ACROSS the entire curbing (car bouncing and all) and then make a HARD right to get back on course before hitting the wall head on.
He talking about the Nascar chute leading to our T7. There was some curbing there that they were running on both sides of and having to jump back before they got to the wall before T7
That was pretty cool....also why they were saying the Kasey Kahne was ok even though his clutch was screwed up. I think that later proved untrue, but I guess that was he concept.
Yes, I was referring to T11 (I just pulled up the official track map). They really slowed down for that turn.
That corner is a blast to drive. Launch over burm then hustle it back to the right to miss the wall...yeeehaaaaw!.....We don't get to run it often..usually the test day before the NASCAR weekend is all...
Sears Point is very fun... and don't forget the Porsche Racing Club (PRC) will be there this weekend. I have run the NASCAR configuration... it is interesting but not as fun as running the carousel. As most of you could probably tell, it can be a somewhat dangerous track. For example, at least 5 people were killed there in '98, but since then there have been a lot of safety improvements. I have seen all sorts of wrecks there, and watched a friend helicoptered out as recently as last fall. There are some cool PRC videos you can find on line, for example, there is one of a driver in our Spec 911 series and another one of two GT combatants going back and forth.
Interesting comments comparing Mark's 928 to the NASCAR machines... those things are just really heavy and have skinny tires compared to many of our Porsche GT cars. They would not be able to keep up with our fastest GT cars, despite the big V8 power.
such a strang place to put a birm, its almost like a car pool lane!
I wonder if they knew folks would be strattling it and then ducking back in before the wall. very cool to watch, but i liked them better on the old track.
Mk
Mk
I do remember when nascar was running the tradition track that we all run now. Remember ALMS running near 1:37-8s for GT2? Thats about what Nascar was doing. still a pretty quick clip. Hey, there is a V8 porsche that has run 1:39.9 (Anderson's 928 stroker monster) I think Stefanowitz was running in the 1:37s almost always, but he hasnt been out for a while.
They do have pretty skinny , but real sticky tires though. Did you see them through the "S's"? OMG, they were lifing that inside tire about 1 foot off the ground. it was very strange to see. These things have some stick and some muscle behind them!
Here is a video from our season opener at Infinion Raceway. It was the season opener for SCCA ITE this year. still in the 1:49s (best 1:47.9) but then again, the car hasnt changed a bit in 7 years. not even an alignment!
http://www.vimeo.com/907502
Mk
Mk
And then there's the total abortion of a configuration that IRL runs (the bike config). Where they.......well, just go look at a track map to see how they chicane down 9, then bypass real T11 to just a 180 around the infield tower. Old ALMS cars could handle the full track; someone explain to me why IRL cant'?
dont forget the short turn7 vs the long turn 7.
The bikes and IRL using the removed turn11 config (turn 11 now well shorter right after turn 10 in bike and IRL config) , is probably due to trying to keep the cars in view of the grandstands as well as having a few hundred feet of run out if someone was to lose their brakes. (turn 11 has walls, buildings,etc)
mk
mk
mk
mk
