Adjustable Impact wrench
Hi, does anbody know of a good quality, cordless, impact wrench that allows you to set the torque at 96ftlbs for wheel lugs. On my normal drill you can adjust the torque (so you don't strip screw heads). I would imagine they make an impact also, but I can't find one online.
TIA
DR
TIA
DR
Hates Family Guy
What series are you running - Grand Am, ALMS, Nascar?
Even endurance racing we use a torque wrench. An impact wrench by its design cannot stop at a specific torque with any degree of accuracy.
I don't trust torque limiting sockets or torque sticks either.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
These cordless impact guns certainly save you time. I use one for removing lugs, then spinning them on just to nip up the wheel, torque wrench after that.
I have been using the Pep-Boys special branded as 'Goodyear' -- $69.00 with rebate -- couldnt pass it up. Once it breaks, I will more than likely be headed to a name brand gun.
I always torque w/ standard torque wrench, but the drill gets them much closer. On a fresh battery I normally need about 1/8 turn to get full torque, but on a battery that's done two 'set changes' I normally need a 1/2 - 3/4 turn to get full torque by the time I get to the last wheel.
I've used a Dewalt 18v cordless for the last 3-4 years and it's great for speeding up the process, but I still use a torque wrench to do the final tightening.
TIA
DR
TIA
DR
