Give me your enduro race suggestions--first 12 hour race coming 6/14
Old 06-17-2008, 04:49 PM
  #31
Phokaioglaukos
Phokaioglaukos's Avatar
Originally Posted by VaSteve
Gotta watch out for you Resientoter guys! We're sitting in the pits and a dark grey 996 with Dougherty graphics and numbers comes pulling up the pit lane in the middle of the race!! We all thought the driver was going to pull onto the course.
This the guy?
Old 06-17-2008, 07:41 PM
  #32
Kurt R
Hates Family Guy
Kurt R's Avatar
Originally Posted by Professor Helmüt Tester
Whoever told you guys that drivers had to stay in the cars during a black-flag was incorrect. Drivers may exit the car...and a good portion of the field did climb out and find other shelter.
There were a lot of messed up things in the pit lane. I'd run Rennlist out of disk space if I listed them all.
Here's our photos. http://autoxrs.net/2008-12hrs/index.htm
Old 06-17-2008, 09:02 PM
  #33
VaSteve
VaSteve's Avatar
Originally Posted by Phokaioglaukos
This the guy?
Yeah I think so.
Old 06-17-2008, 09:04 PM
  #34
bobt993
bobt993's Avatar
Chris, nice pic, I know who that is now.......... May need a full size copy to frame and add to the wall of shame at the banquet. Could have been the first time someone ever "won" (or lost) anything at a DE.
Old 06-19-2008, 02:39 PM
  #35
Cory M
Cory M's Avatar
Some good enduro race advice
(copied from here: http://nasaforums.com/viewtopic.php?f=21&t=20435)
Tip 1: Finish building the car at the track, the Friday test day before the 25. Bonus points if it sits at the cage shop for 2 months with no work done to it.
Tip 2: Use your first stint to measure your fuel consumption. Bonus points if you run out of fuel on track. Double bonus if the crash crew drags you across the front straight within 100 yards of oncoming traffic.
Tip 3: Make sure the seat is positioned so that your helmet gently thumps the cage halo padding with every bump. After 45 minutes of this you will have a migraine, and the pain will keep you alert for the rest of the stint. As a bonus the migraine response time drops with each repetition, so by the final stint it only takes about 10 minutes.
Tip 3: Make sure you have at least one exhaust leak inside the car. Nothing helps keep you awake like asphyxiation.
Tip 4: Make sure you route your fuel cell vent near the exhaust outlet, nothing keeps a driver on his toes like a fire. Bonus points if your car actually catches fire, but only if it happens on the practice day. Double bonus points if your driver is able to put the fire out on the back straight
Tip 5: If given the choice of colliding with an overly agressive d!ckhead in a Miata or careening across a cow pasture at 90 miles per hour, choose the d!ckhead every time.
Tip 6: Bring a welder. Bonus points if you use it more than 3 times in the course of the race. Double bonus points if the stuff you weld on during the race weighs more than the parts that fell off after not following tip #5.
Tip 7: Only bring enough food to last half the race. Bonus points if some of the crew (always the hardest workers) and drivers don't get any food at all.
Tip 8: If one of your crew says "That ain't right!" ignore him. There is plenty of time to replace a loose bolt once it falls out completely.
Tip 9: Don't worry about flaky driving lights. When they fail, you can see just fine with the 55 watt apex lights which are aimed at 10 and 2 o clock. Don't wire up your stock headlights as a backup. Having functioning lights is just extra drain on the alternator, and that robs power.
Tip 10: If anyone on the crew decides to stick a sponsor sticker on the crash truck, make sure to put it on the brand new vinyl stripes where it is nearly impossible to remove without damage. Don't put it on the paint, where it is easy to remove. Jerry won't go berserk, honest.
Tip 11: If you are entering an EVO, make sure you have at least 3 street cars you can rob parts off when they break.
Tip 11a: Make sure you invest three times as much effort in securing matching sponsor-branded clothing, including two types of matching hats, than in practicing your pit stops. That way you look like morons during the race and prompt laughter, contempt and a little pity from your pit neighbors.
Tip 12: If you are using a fuel rig, don't check the length of the fuel hose, you can always move the car closer to the rig during the first stop when you discover it is too short. Well, once you locate and reinstall the steering wheel.
Tip 13: Make sure you use the cheapest crappy radios you can find.
Tip 14: Ensure anyone acting as a spotter is blissfully unaware of the concept of brevity, or for that matter how to talk on cheap crappy radios. Have them talk quickly with lots of unnecessary detail, so they sound exaclty like Charlie Brown's teacher.
Quick Reply: Give me your enduro race suggestions--first 12 hour race coming 6/14
