Question for Aiptek HD users
Does this include the A-HD+ model that many of us purchased?
Agent Orange
I would think so, if the A-HD+ is in the same enclosure as the A-HD.
There is a way to correct that problem, to a degree. You can superglue the bottom of the case by the base of the mount, where the two parts of the case connect. That helps a lot, but it's not as good as a metal-to-metal mount. The plastic will always flex.
NASA Racer
I put some paper towels between the camera and the mount and it seemed to help with the vibration. Either that or the Glen is just that much smoother than Lime Rock
The Penguin King
Whenever I plug any sort of mini-usb cable into my A-HD, it goes into charge mode, and won't record. Am I missing something? Is there a specific AC adaptor, or car power adapter that allows you to film while plugged in?
