Precautions When Drilling Lead.
Well, if I end up drooling, have a twitch in my neck or a limp pecker, I'm blaming you guys for all this help. Yeah right. Lead the blind man off the cliff. ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Pat, I'll check into the VIR event August. I had to back out of a 3 day event next week because work got in the way.
Mark, I'm the luck one. I'm guessing you have drilled a lot of lead based on the 3 offs, or was it 4, in the CR Enduro.
depending on how soft the lead is you may need to touch the drill face (2 sides) in a grinder to dull it so the drill doesn't bite too hard. This will allow the drill to "cut" through the lead instead of being sucked through it.
Bill
Bill
Originally Posted By: bobt993
Bill added what I was going to say. Typical lead ballast is pretty soft and really grabs the drill bit. You may what to use a versi-bit.
http://www.irwin.com/irwin/consumer/...IrwinCat100138
Be careful if you have a keyless chuck.......... a good way to lose a digit.
Mr. Excitement
You might be able to use a spade bit. It is a flat bit with sharp edge and a spike like center made for larger dia holes in wood. They are about 6 inches long and thus you will not need an extention. No issues with the bit diving and over filling the flutes.
If you drill it with a flat paddle bit, you better clamp the thing in a vice and start with a much smaller bit. It will spin like a top otherwise. I spun a 25lb brick with a 18volt cordless and a 3/8 bit nearly breaking my wrist.
Mr. Excitement
Stand on lead block to eliminate unclamped work torque reaction. Set the drill clutch to the highest setting but not on "drill" which is no clutch. Rest the drill against your legs between your feet to control feed rate. Drill using high speed and feed in gently.
