What should I have done differently.......
#107
Most clubs & instructors have found that less experienced drivers learn faster on "street tires".
In order to carry speed... street tires will force you to be smooth with driver imput and the slightly slower cornering speed is more forgiving, allowing the driver to experiment a bit in trying slightly different lines/braking and turn-in points... without risking off track adventures.
The driver wil know when he has max'ed out on street tires... even with consistent smooth driving... the street tires will begin to get "greasy".
Now the driver is ready to move up to Dot "R" tires... he's learned how to consistantly drive the proper line with smooth imputs... maxamizing the street tire's ability.
You may think this is a step backwards... but believe me, following this proceedure will make for a better driver who continues to learn from a solid foundation.
Best of Luck Paolo, you have come a long way from where you first started posting.
Cya @ the track,
Trumper
Cya @ the track,
Trumper
#108
Cya @ the track,
Trumper
Cya @ the track,
Trumper
Hope to meet you one day.....
#109
Perfect Angel
The gas should be, depending on the car, progressively on from t5 or t6 until you are flat out at or coming out of t9. Agin, this depends on the car. Kurt M is standing on it all the time, RSR cup may need to manage the throttle differently. I give it a little more at each turn, still too chicken to be flat out until a tick past t9 apex as long as I'm sure the crown in the track won't send me into the tires/rocks/trees.
#110
Did I mention that the Boxster driver is not only a good driver but devilishly handsome as well?
The log book has it registered as stock F class. It doesn't get much more stock than that.
Originally Posted by Gary R
Well, his Boxster sure as heck doesn't look stock!
#111
#113
Ironman 140.6
+1 I have not driven this track but you appear to take an early apex on several corners
#118
Ok, my car isn't quite showroom stock but it's probably a bit closer to it than Paolo's class winning race car. Wasn't that car bumped up a class as a prepared car?
#119
Paolo, here is some advice that I give in my advanced classroom sessions:
Learning A New Track 101 = late apex everything to start, then start GRADUALLY moving apexes earlier until you begin to run out of track out and/or lose exit speed/RPM's....then move back a smidgen.
#120
Perfect Angel
Here's another tactic:
Use the skinny pedal more or try lavender panties instead of "salmon" next time!
Oh yeah, make sure they are clean in case you have an accident . . . .
Oh Snap!
Oh Snap!
