Anybody use these (pics inside) Griot's wheel storage hangers?
Dell,
When I tackled my garage project in the summer of 07, I had some dead space behind one of the main beams going through the garage. I decided to take advantage of the space for storage. Besides building a hanging shelf, I also built a tire rack using ½ black pipe in a 8'x18" configuration. I also used 2x3 wood anchored to the ceiling joist and wall in order to distibute the weight out evenly. I chose to hang the tire rack via straps attached to O-hooks as seen on the pictures.
Maybe went overboard with the straps and o-hooks (anchored at 90 and 45 degree's) however, safety first. Since then the garage door has cycled numerous times without having any negative affect due to vibrations. The total cost of the rack was somewhere in the $50 range.
This summer I plan on finishing the project by painting the 2x8 and organizing the straps.
I really the tirerack version and since my wall is pretty long, I could two side to side. Thanks guys for the info, never thought of looking at tirerack (even though the store name says it all!!
Never a fan of those poles. While I'm sure they work well, I would constantly be hitting my head or knee on them. I went with the homemade 2x4 version. I have a $40 materials one in the basement, and a larger $50 version in the garage (it is longer to fit in the space I had). Lots of wheel/tire storage and minimal footprint.
Takes up precious floor space ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks everybody for all the suggestions, pictures, and experiences. I think I am going with the Tire Rack system that was suggested. Seems to be EXACTLY what I am looking for.
I'll post back when I get it installed.
Cheers!
Cheers!
Noel
Stacking is what I do, and it goes with the trashy look of my garage, a look, I am sure I will keep. However, I personally like the 2x4 setup of Mike Buck, and it looks cheap, which I am. For some reason, the tire/wheel I need is always on the bottom of the stack. Plus if you stack them too high, they fall over, and scare the cats or dog.
Bill
Bill
Don't care to do a tire rack on the wall for 2 sets of wheels and thought 4 of these would be great to accommodate 8 wheels. Anybody have any comments on them?
LINK
TIA!![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
LINK
TIA!
I don't know, I'm just guessing
Dell, the only thing I see as a slight negative is the required wall space/4 tires. Ea. unit has a 66" OD. I bet you need more than 1 unit for your inventory.
I have been musing on the tire problem in my garage as well. The tire rack solution is pretty good but, I have around 24 tires and rims. That is a lot of 4 tire racks and lots of wall space.
Has anyone built or considered building a double height, double width, rack using 2" PVC. I did a bend test on a piece I have at the house and found it to be VERY strong. The only dilemma I haven't solved is attaching casters. I need to be able to roll things around for sweeping and moping of the floor. If anyone has pics of this setup or suggestion I'd like to see them.
I think you could build this system for under $100 depending on casters. I would use 4" Swivels
w/locking fronts.
w/locking fronts.
Noel
Bill
Bill
King of Cool
Wouldn't you the folding one like posted above? The tire rack rack is help by the top and their might be a pressure pushing against the wall (see rubber pucks). Creating a cantilever effect. Wouldn't that be too much for thin trailer walls?? The folding racks seem to be screwed at the top and bottom and then unfolds like a chair.
I don't have the foam on all the rack bottoms, but you get the idea. If I had track tires with softer compound rubber I'd line the bottoms of the support arms with the foam to prevent "cutting" or "imprinting".
Noel, I like those tire covers, where'd ya get em>
Shustermeister
Those gorrilla racks came from COSCO uh? Any place else to get them? The COSCO employee that got me a COSCO card got fired. So they wouldn't let me buy the last time I went there. I sure hate to pay to shop, but I guess I have no choice, cause those things look neat, and fairly easy to assemble for an unhandy guy like me.
Bill
Shustermeister
Bill
